Inleiding
The thermostat and gasket will set you back about $10 from any auto parts store. The entire process should take less than 30 minutes. Good luck.
Wat je nodig hebt
MAKE SURE ENGINE IS COLD Locate the upper radiator hose and follow it to the location where the hose connects to the engine block. The hose clamps to a metal housing called the "water inlet." Loosen the band clamp that secures the hose to the water inlet with a screwdriver. Pull the hose off the inlet.
Place a bead of RTV gasket maker around the bottom edge of the water inlet. Place the water inlet over the thermostat and bolt it into place. Using RTV gasket maker instead of a gasket compensates for pitting that occurs in cast iron. It helps to promote a better seal between the engine and the inlet.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
When I start the car it's shack and the gass race go up and down
