Inleiding
If the rear window of your 2001 Chevrolet Suburban won’t stay open, the struts (also known as lift supports or lift support struts) that hold it up need to be replaced. This guide will walk you through replacing these struts. It’s important to replace failing struts because an unsupported window has the potential to dangerously drop on your head or shatter against any cargo sticking out.
Special Considerations
You’ll want to consider the following:
- Having a partner is immensely helpful. Having someone hold the window open is easier (and safer) than propping it open.
- Some users may need a step stool. Due to the height of the upper strut joints, some users may find it more comfortable to use a step stool or step ladder.
Hazards
This procedure isn’t dangerous, but be aware of the following hazards:
- The window could fall and hurt you. Be sure it’s secure.
- The tabs on the struts could be flung into your eyes. The risk of this is low unless you try to completely remove the tabs or use excessive force when loosening them.
- The grease on the strut joints and mounting studs is toxic. Wash your hands when you’re done.
Wat je nodig hebt
Open the window.
Support the window with either a partner's hands or a sturdy prop.
Repeat this process for the other strut. That’s it!
