Ga door naar hoofdinhoud
2001-2005 Honda Civic Tail Light Replacement
  1. 2001-2005 Honda Civic Tail Light Replacement, Tail Light: stap 1, afbeelding 1 van 1
    • To remove the risk of electrocution, turn off the vehicle before attempting replacement
  2. 2001-2005 Honda Civic Tail Light Replacement: stap 2, afbeelding 1 van 1
    • Release the trunk latch.
    • The release can often be found on the floor, near the fuel access and hood release buttons.
  3. 2001-2005 Honda Civic Tail Light Replacement: stap 3, afbeelding 1 van 1
    • Remove bulb from tail light assembly.
  4. 2001-2005 Honda Civic Tail Light Replacement: stap 4, afbeelding 1 van 1
    • Remove the bulb from its' socket.
    • Be sure to only remove the bulb. Removing the socket as well will require another replacement in order to properly function.
Conclusie
To re-install a tail light, follow these steps in reverse.
Tyler Smith
846 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 Lid van UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G5
3 Leden
5 handleidingen geschreven
1Gids Commentaar
I have an issue with the bulb being stuck in the socket. I can access the whole assembly fine, but for whatever reason the bulb won't come out.
Kyle - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 40
Altijd: 9,075
