Ga door naar hoofdinhoud
2001-2005 Honda Civic Battery Replacement
Wat je nodig hebt
  1. 2001-2005 Honda Civic Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Caution! Vehicle must be turned off before attempting this replacement. Touching the battery terminals while the car is running may cause risk of electrocution.
  2. 2001-2005 Honda Civic Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the connections from both the negative and the positive terminals of the battery
    • When removing the battery, the negative terminal must be removed first. When re-installing the battery, the positive must be connected first.
  3. 2001-2005 Honda Civic Battery Replacement: stap 3, afbeelding 1 van 1
    • Using a socket wrench, remove the battery bracket from the top of the battery.
    • Depending on the condition of the car, the bolts may be rusted, making the removal of them a challenge.
  4. 2001-2005 Honda Civic Battery Replacement: stap 4, afbeelding 1 van 1
    • Ensure that there are no connections remaining on the battery.
    • Lift up the battery and remove it from the battery tray.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Tyler Smith
846 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 Lid van UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G5
3 Leden
5 handleidingen geschreven
1Gids Commentaar
Terrible! These sparse instructions leave out so many steps, both for safety and for completion of the task, that anyone performing this task for the first time will have no idea what to do.
Mark - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 205
Altijd: 39,375
