Ga door naar hoofdinhoud
2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement
Wat je nodig hebt
    1. 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement, Suction Fuel System and Fuel Filter: stap 1, afbeelding 1 van 3 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement, Suction Fuel System and Fuel Filter: stap 1, afbeelding 2 van 3 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement, Suction Fuel System and Fuel Filter: stap 1, afbeelding 3 van 3
      • Attach 10 mm socket to a 1/4" ratchet wrench and loosen the bolt on the left side and then the right.
      Vraag FixBot
      Voeg opmerking toe
    2. 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement: stap 2, afbeelding 1 van 2 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement: stap 2, afbeelding 2 van 2
      • Apply the thread sealant to the four bolts that will be attached to the new top base of the new fuel filter.
      Vraag FixBot
      Voeg opmerking toe
    3. 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement: stap 3, afbeelding 1 van 1
      • Screw the four bolts with the thread sealant to the new top base of the new fuel filter.
      Vraag FixBot
      Voeg opmerking toe
    4. 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement: stap 4, afbeelding 1 van 1
      • Attach the two two-inch clamps to the two fuel lines.
      • Then attach the fuel lines with the two two-inch clamps to the new top base.
      Vraag FixBot
      Voeg opmerking toe
    5. 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement: stap 5, afbeelding 1 van 1
      • Screw the two-inch clamps with the paddle screwdriver until is secure to the fuel line.
      • Repeat the previous process on the other fuel line.
      • Finally, screw the new Racor fuel filter to the top base.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 102
Altijd: 2,255
