Ga door naar hoofdinhoud
1999-2002 Suzuki SV650 Seat Replacement
Wat je nodig hebt
  1. 1999-2002 Suzuki SV650 Seat Replacement, Seat: stap 1, afbeelding 1 van 2 1999-2002 Suzuki SV650 Seat Replacement, Seat: stap 1, afbeelding 2 van 2
    • If you have frame covers below your seat, remove them by removing the 4 mm allen bolts holding them on. Use a 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • Once the frame covers are off, remove the 4 mm allen seat bolts on both sides of the seat. Use the 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • The bolt in the picture is not stock.
    • Lift the front of the seat, then pull it off the frame.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Phillip Takahashi
86.842 Reputatie
87 handleidingen geschreven
Één opmerking
seat bolts are actually 6mm Allen (side covers are 4mm Allen).
thineownself - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 41
Altijd: 8,020
