Ga door naar hoofdinhoud
1999-2004 Volkswagen Golf Front Windshield Wipers Replacement
Wat je nodig hebt
  1. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement, Front Windshield Wipers: stap 1, afbeelding 1 van 1
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  2. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: stap 2, afbeelding 1 van 1
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  3. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: stap 3, afbeelding 1 van 2 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: stap 3, afbeelding 2 van 2
    • Gently lift up the passenger-side windshield wiper.
  4. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: stap 4, afbeelding 1 van 1
    • Remove the driver-side windshield wiper in the same fashion.
    My windshield wipers were stuck on like they were welded. I removed them with channel lock pliers. I put the top jaw of the pliers and placed it under the wiper and the bottom claw of the pliers and put it on the mounting bolt. squeezed as hard as I could and Pop! It came loose.
    Nils Stansen - Antwoord
Conclusie
4 andere personen hebben deze handleiding voltooid.
Matthew Newsom
39.496 Reputatie
67 handleidingen geschreven
Één opmerking
one has to be careful with the rain tray. if you use too much pressure whil trying to get the wipers off, you will damage (crack) it.
there is a special tool for getting them off; this is a bit pricey.
elchmartin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 22
Altijd: 13,764
