Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a #2 Phillips screwdriver to remove the four screws.
Use a flathead screwdriver to remove the cap from the windshield wiper.
Use a socket wrench to release the passenger-side windshield wiper locking nut.
Gently lift up the passenger-side windshield wiper.
Remove the driver-side windshield wiper in the same fashion.
Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
Use a #2 Phillips screwdriver to remove the front two screws.
Gently unplug and lift out the automatic transmission control unit.
8 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
does it need to be programmed mine needs replacement my gears are not shifting
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
