Inleiding
Using this guide, you will be able to safely and quickly replace the headlight bulbs in a 1999-2004 Nissan Xterra.
This guide highly recommends that you remove the battery if you are replacing the right headlight. Removing the battery, while not necessary to replace the headlight bulb, allows for easier access to the back of the headlight and will save you time and stress when re-screwing the retaining ring at a difficult angle.
For more relevant information, please read this 2004 Nissan X-terra Owner’s Manual on page 8-33.
Wat je nodig hebt
To replace the headlight bulb, follow these instructions in reverse order with the new halogen bulb. When inserting the new bulb, ensure that the plastic outcropping is facing up to ensure that the bulb stays secure.
3 andere personen hebben deze handleiding voltooid.
