Ga door naar hoofdinhoud
1999-2004 Nissan Xterra Headlight Bulbs Replacement
Wat je nodig hebt
  1. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement, Headlight Bulb: stap 1, afbeelding 1 van 2 1999-2004 Nissan Xterra  Headlight Bulbs Replacement, Headlight Bulb: stap 1, afbeelding 2 van 2
    • Reach under the driver's cabin panel and pull on the hood release.
    • It is about 10 inches from the left edge of the panel.
    • After pulling the release, you will hear a "pop" sound indicating that the hood is open.
  2. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: stap 2, afbeelding 1 van 1
    • Pull up the hood release latch.
    • It is located about 6 inches to the right, from the center of the hood.
  3. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: stap 3, afbeelding 1 van 2 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: stap 3, afbeelding 2 van 2
    • Insert the hood support.
    • The support is located about 4 inches behind the hood latch opener.
  4. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: stap 4, afbeelding 1 van 3 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: stap 4, afbeelding 2 van 3 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: stap 4, afbeelding 3 van 3
    • Squeeze and disconnect the electrical component from the rear end of the bulb.
    • The squeezing should be done by placing one finger above and another below the component.
  5. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: stap 5, afbeelding 1 van 3 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: stap 5, afbeelding 2 van 3 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: stap 5, afbeelding 3 van 3
    • Turn the retaining ring counterclockwise until it is free from the headlight.
    • Remove this component and set it aside.
  6. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: stap 6, afbeelding 1 van 2 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: stap 6, afbeelding 2 van 2
    • Carefully remove the headlight bulb.
    • The headlight bulb is immediately behind the retaining ring removed in Step 5.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
Conclusie
To replace the headlight bulb, follow these instructions in reverse order with the new halogen bulb. When inserting the new bulb, ensure that the plastic outcropping is facing up to ensure that the bulb stays secure.
3 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 44
Altijd: 5,481
