Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement
Wat je nodig hebt
  1. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear Hatch lift supports: stap 1, afbeelding 1 van 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear Hatch lift supports: stap 1, afbeelding 2 van 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear Hatch lift supports: stap 1, afbeelding 3 van 3
    • Open the tail gate and either prop it up or use an assistant to hold it.
    • The tail gate is heavy and will fall if not properly supported.
    • The rear hatch has both a left and right lift support strut.
  2. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement: stap 2, afbeelding 1 van 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement: stap 2, afbeelding 2 van 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement: stap 2, afbeelding 3 van 3
    • The struts are fastened with T40 Torx head bolts.
    • Use a T40 Torx driver to loosen the bolt
    • The bolt does not remove the strut. It is pressed in to the strut and will be replaced with the new strut.
  3. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement: stap 3, afbeelding 1 van 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement: stap 3, afbeelding 2 van 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement: stap 3, afbeelding 3 van 3
    • Completely loosen the bolt securing the strut to the top of the tailgate with a T40 driver.
    • Replace the worn strut with a new one.
    • On this vehicle both struts were replaced. This will stop the tailgate from sagging.
Conclusie
To reassemble your Jeep, follow these instructions in reverse order.
8 andere personen hebben deze handleiding voltooid.
oldturkey03
781.130 Reputatie
119 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
32 Leden
530 handleidingen geschreven
4 opmerkingen
We just had a garage replace the tailgate lift struts on our 2002 Jeep Grand Cherokee. Now the tail is very difficult to pull closed. Is there a way to adjust the struts so that it easier to pull down closed??
Raymond Janko - Antwoord
Double check the work. Make sure they are mounted the right direction and that all the bolts are properly fastend. There are no adjustments
oldturkey03 -
I need to replace the lower bolt as it snapped in half. Any advice for that?
Dave Hankins - Antwoord
Use a drill and drill off the head. Remove the strut and use something like a pair of vise-grips and get a grip on the leftover part of the bolt. Try to remove it. If you can/ time to drill it out and retap the thread.
oldturkey03 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 57
Altijd: 9,875
