Ga door naar hoofdinhoud
1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement
Wat je nodig hebt
  1. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: stap 1, afbeelding 1 van 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: stap 1, afbeelding 2 van 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: stap 1, afbeelding 3 van 3
    • Here is the Jeep GC. Removal of the headlamp is identical for both sides.
    • By opening the hood and looking straight down on the headlamp assembly, the 6mm hex head jack screw can be seen.
    • Use a 6mm socket and nut driver to remove the jack screw. 1/4 socket will not fit 9/32 does, but it is a bit sloppy
  2. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: stap 2, afbeelding 1 van 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: stap 2, afbeelding 2 van 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: stap 2, afbeelding 3 van 3
    • Remove the long jack screw.
    • Grasp upper inboard and lower outboard corners of headlamp and forcefully pull headlamp outward.
    • Remove all bulb sockets from headlamp module. Separate headlamp from vehicle.
Conclusie
6 andere personen hebben deze handleiding voltooid.
oldturkey03
782.162 Reputatie
119 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
33 Leden
537 handleidingen geschreven
4 opmerkingen
It’s a 7mm socket
Don Marcos - Antwoord
Not on mine. Just rechecked and it is a 6mm on my Jeep
oldturkey03 -
Thankful for simple instructions without any extra info or words ?
robinrogersk9 - Antwoord
I’m removing it to replace fan cooling module. I heard I can cut through to get to it without disassembling the grill bumper etc
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 37
Altijd: 7,560
