Inleiding
This guide is to remove the headlamp. Left and right remove identical. This will have to be done to either change a light bulb or to remove the complete headlamp for exchange.
Wat je nodig hebt
Here is the Jeep GC. Removal of the headlamp is identical for both sides.
By opening the hood and looking straight down on the headlamp assembly, the 6mm hex head jack screw can be seen.
Use a 6mm socket and nut driver to remove the jack screw. 1/4 socket will not fit 9/32 does, but it is a bit sloppy
6 andere personen hebben deze handleiding voltooid.
4 opmerkingen
It’s a 7mm socket
Not on mine. Just rechecked and it is a 6mm on my Jeep
Thankful for simple instructions without any extra info or words ?
I’m removing it to replace fan cooling module. I heard I can cut through to get to it without disassembling the grill bumper etc
