Ga door naar hoofdinhoud
1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement
Wat je nodig hebt
  1. 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Passenger side window regulator (power windows): stap 1, afbeelding 1 van 3 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Passenger side window regulator (power windows): stap 1, afbeelding 2 van 3 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Passenger side window regulator (power windows): stap 1, afbeelding 3 van 3
    • First locate the 4 screws to remove the door panel. See pic1
    • 2 screws are visible.
    • The other 2 screws are behind items.
    • Location of the screws.
    • First screw is under the door lock/window controls. See pic 2.
    • Next screw located lower right of panel behind reflector. See pic 3
    • To remove the door/window controls pry on one end of the controls and lift up. See pic 2.
    • To remove the reflector pry one side and remove from the panel. See pic 3.
  2. 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Removing panel from door.: stap 2, afbeelding 1 van 3 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Removing panel from door.: stap 2, afbeelding 2 van 3 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Removing panel from door.: stap 2, afbeelding 3 van 3
    • Before removing panel, remove small tweeter speaker from top of door panel.. Clipped in just pull the top. Pic 1
    • After removing screws, Pull on the panel around the outside to release the pop-in clips.
    • Then remove the panel from the door by lifting up and backward on the panel. Pic 2
    • Be mindful of the rail on top of the panel that may or may not fall off the panel.
    • Also make sure you remove any wires that is connected to the door panel. Lock controls, tweeter speaker wires.
    • On the bottom of the glass inside the door there are two bolts that hold the window to the plastic track on the regulator.
    • Before you remove the second screw hold the window to prevent breakage of the window.
    • While holding the window remove the second screw and lift out the window from the door.
    • Locate and loosen the 4 bolts holding the regulator. See pic 1.
    • Then remove the window regulator motor and all of the track from the door...
    • Then replace the regulator and reverse the procedure to install the regulator back in the door.
Conclusie
4 andere personen hebben deze handleiding voltooid.
shawn streitmatter
251 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 8,878
