Ga door naar hoofdinhoud
1999-2006 BMW 3 Series Headlight Bulb Replacement
Wat je nodig hebt
  1. 1999-2006 BMW 3 Series Headlight Bulb Replacement, Headlight Bulb: stap 1, afbeelding 1 van 2 1999-2006 BMW 3 Series Headlight Bulb Replacement, Headlight Bulb: stap 1, afbeelding 2 van 2
    • Prior to beginning the repair, open the the hood of the car and disconnect the battery.
    • Remove the two bolts on top of the headlight assembly using an 8mm socket wrench.
  2. 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 2, afbeelding 1 van 3 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 2, afbeelding 2 van 3 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Microfiber Cleaning Cloths
    $3.99
    Koop
    • Start by placing your flathead screwdriver inside the microfiber towel.
    • Then, insert the covered flathead screwdriver in the vertical space below the headlight.
    • Next, push the screwdriver while wiggling it side to side against the small tab in the crack. By doing this action you will separate the trim under the headlight from the fender of the car.
  3. 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 3, afbeelding 1 van 2 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 3, afbeelding 2 van 2
    • Slide the headlight assembly out.
    • Place the microfiber towel on the bumper; set the headlight assembly face down on it.
  4. 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 4, afbeelding 1 van 2 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 4, afbeelding 2 van 2
    • Remove the four screws with the Phillips #2 screwdriver.
    • Next, remove the backing plate to gain access to the headlight bulb.
  5. 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 5, afbeelding 1 van 3 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 5, afbeelding 2 van 3 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 5, afbeelding 3 van 3
    • Once the backing plate is removed, free the headlight bulb by pushing down on the retaining bracket. Push towards the direction of the red arrow.
    • Next, lift the retaining bracket and remove the headlight from the assembly.
  6. 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 6, afbeelding 1 van 2 1999-2006 BMW 3 Series Headlight Bulb Replacement: stap 6, afbeelding 2 van 2
    • Once the headlight bulb is removed from the housing, separate the bulb from the connector by wiggling it out.
    • Do not grab the glass while attempting to remove the bulb from the connector. Instead grab the metal plate near the connector.
    • Lastly, insert your new bulb and follow the steps in reverse order to reassemble.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 281
Altijd: 11,072
