Inleiding
Whether you have an uncomfortable bench seat or your seats are just worn and torn, replacing the seats in your Ford Super Duty with new take outs or lightly used seats from a newer model truck is a great way to update your truck and make it more comfortable. 1999 - 2010 Seats are directly compatible. Today we are going to replace the seat in a 2005 model with a 40/20/40 seat from a 2013 Super Duty. With very light modification any seat up to 2014 will fit any truck back to 1999 with light modification.
Wat je nodig hebt
Before shot of bench seat in a 2005 Ford F-350 Super Duty. Removal of the seat requires an 18mm socket. Preferably a deep wall socket and a T60 Torx Bit w/ratchet or impact wrench.
Adjust seat to it's most forward position. Look for a stud with a plastic protection cap. Remove the cap with a screwdriver. Using an 18mm wrench or socket (if space allows) remove the bolt from the stud. On my bench seat there were only two studs/bolts. Other style seats will have more. Lift seat off studs and position seat forward of studs.
Next, if your truck was only using the outter body holes you will need to locate the two close to the transmission tunnel. You can press your finger in the center and locate the opening. Take a razor knife and gently cut an X over the hole. Gently remove each of the triangle shaped tabs exposing the additional hole. Repeat on opposite side.
Next place your jump seat in the middle on top of the transmission tunnel. The rear holes will line up with two of the existing holes where the seat belts were attached. Place two bolts in the holes but don't tighten completely. Lift the bottom seat up exposing the two bolt holes in the bottom of the jump seat.
Now mark and drill two holes in the transmission tunnel. Carefully check what is below the tunnel to make sure you don't damage wiring or other system that may be run along the path. This is best done with one person drilling and one person watching underneath. These are the only holes you must drill for 2011 to 2014 seats to fit.
In my case the seat belt buzzer on the new seat didn't match the vehicle plug. Simply remove the seat belt receiver from the side of the seat with a T60 Torq bit and re-attach your old seat belt receiver to the floor bolt. Using the old seat belt receiver gives you the proper connector and allows the buzzer to work properly.
Replacing uncomfortable or worn out seat really improves your truck!
21 andere personen hebben deze handleiding voltooid.
41 opmerkingen
Thanks for the amazing writeup! We are linking to here from our website on an upcoming blog. Once again, thanks for your business. Glad we could assist in your project.
-Keith B
1-844-OEM-SEAT
I see that your truck is the extended cab, will this work a single cab? I have the same year truck as a work truck but the bench seat is really uncomfortable on long trips. I would love that jump seat specially since it also works as a center console.
From my understanding the front seat is the same regardless if it is a single cab, extended cab, or 4 door. If you will contact the good folks at http://www.oemcarandtruckseats.com/ I believe they can definitely answer your question. I can tell you this, if you change your bench seat out for the buckets with the jump seat it will be a 150% improvement in comfort.
JNoles -
