Inleiding
If your '98 - '02 Honda Accord speedometer is performing erratically, or not at all, your vehicle speed sensor may be damaged or broken. Use this guide to replace your damaged vehicle speed sensor.
Wat je nodig hebt
Pull on the hood release lever just inside the passenger door to pop the hood.
Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood.
Insert the hood prop rod into the hole in the hood marked with an arrow.
Locate the engine air intake unit on the back of the engine.
Locate the screw for the hose clamp securing the air intake hose to the engine's air intake unit.
Loosen the the hose clamp, using a Phillips #2 screwdriver, by turning the screw counter-clockwise until the back end of the screw no longer protrudes out of the hose clamp.
29 andere personen hebben deze handleiding voltooid.
23 opmerkingen
Hey I raplace the speed sensor but my speed gage it still doesn't work, any other Ideas what else can it be?
Try getting a manual (Haynes?) and check the wiring as suggested. Maybe try a different gauge cluster?
Detach the sensor cable before pulling the sensor out. I used 2 shorter extensions and went at it from the side. Clean around the sensor before you take it out.
