Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine.
Pull the distributor cap away from the engine and set it aside.
Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange.
Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
13 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Where can I find the part number?
excellent, thanks for you aportation.
