Ga door naar hoofdinhoud
1997-2001 Jeep Cherokee Brake Light Replacement
Wat je nodig hebt
  1. 1997-2001 Jeep Cherokee Brake Light Replacement, Brake Light: stap 1, afbeelding 1 van 1
    • Open the trunk door. In order to remove the rear light assembly, it must be accessed with the trunk open.
  2. 1997-2001 Jeep Cherokee Brake Light Replacement: stap 2, afbeelding 1 van 1
    • Remove the three screws that are holding the rear light assembly to the body of the Jeep. Use the wrench to remove the screws.
    • Each screw is an indented hexagon washer head and is 3/16" in diameter and 3/4" long.
    • All three screws are identical and can be removed in any order.
  3. 1997-2001 Jeep Cherokee Brake Light Replacement: stap 3, afbeelding 1 van 1
    • Gently pull the rear light assembly away from the car to gain access to the bulbs and wires.
    • Be careful when pulling away the rear light assembly. The wires will still be attached to the inside of the car.
  4. 1997-2001 Jeep Cherokee Brake Light Replacement: stap 4, afbeelding 1 van 1
    • Locate the brake light. Turn the light assembly over and you will see three light bulb sockets. The brake light is the top bulb and the bulb behind the red plastic lens.
  5. 1997-2001 Jeep Cherokee Brake Light Replacement: stap 5, afbeelding 1 van 3 1997-2001 Jeep Cherokee Brake Light Replacement: stap 5, afbeelding 2 van 3 1997-2001 Jeep Cherokee Brake Light Replacement: stap 5, afbeelding 3 van 3
    • Remove the brake light. Twist the light bulb socket clockwise and remove the light bulb socket from the rear light assembly.
  6. 1997-2001 Jeep Cherokee Brake Light Replacement: stap 6, afbeelding 1 van 1
    • Remove the bulb by pinching on either side of the bulb and gently pulling the bulb out.
    • Be careful not to force the bulb when pulling as it may damage the bulb socket.
  7. 1997-2001 Jeep Cherokee Brake Light Replacement: stap 7, afbeelding 1 van 1
    • Replace with the new bulb. Gently put in the new bulb in the same manner as you removed the old bulb.
  8. 1997-2001 Jeep Cherokee Brake Light Replacement: stap 8, afbeelding 1 van 2 1997-2001 Jeep Cherokee Brake Light Replacement: stap 8, afbeelding 2 van 2
    • Lock the bulb back in place. Carefully put the bulb back into the light assembly and twist counter clockwise until it locks in place.
  9. 1997-2001 Jeep Cherokee Brake Light Replacement: stap 9, afbeelding 1 van 3 1997-2001 Jeep Cherokee Brake Light Replacement: stap 9, afbeelding 2 van 3 1997-2001 Jeep Cherokee Brake Light Replacement: stap 9, afbeelding 3 van 3
    • Set the light assembly back in place. There is a tab on the bottom of the light assembly that must line up with the hole in the car.
    • The red brake light should be on top.
  10. 1997-2001 Jeep Cherokee Brake Light Replacement: stap 10, afbeelding 1 van 1
    • Tighten the three screws back into place. This will fasten the light assembly back onto the car.
    • The order and the positioning of the screws will have no effect on the assembly, because they are all identical.
  11. 1997-2001 Jeep Cherokee Brake Light Replacement: stap 11, afbeelding 1 van 1
    • Check the brake light. Have another person step on the brake to ensure proper lighting occurs.
Eindstreep
15 andere personen hebben deze handleiding voltooid.
James West
561 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-1, Green Fall 2015 Lid van Cal Poly, Team 15-1, Green Fall 2015
CPSU-GREEN-F15S15G1
5 Leden
6 handleidingen geschreven
3 opmerkingen
Very well done and accurate
Kevin white - Antwoord
It is not easy to get the taillight assembly back into the slot. The side bumper prevents direct access. However, it is possible if done bottom in first gently but firmly.
lionreb - Antwoord
Amazing blog and share so many creative information. I actually look such website for my car. More information about our business please visit us: https://5starsautoparts.com/
5stars auto parts - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 49
Altijd: 26,921
