Ga door naar hoofdinhoud
1997-2003 Chevrolet Malibu Tail Lights Replacement
Wat je nodig hebt
  1. 1997-2003 Chevrolet Malibu Tail Lights Replacement, Tail Lights: stap 1, afbeelding 1 van 1
    • Locate the plastic casing that holds the trunk liner in place, directly behind the tail light.
    • Unscrew the plastic casings.
    Vraag FixBot
  2. 1997-2003 Chevrolet Malibu Tail Lights Replacement: stap 2, afbeelding 1 van 1
    • Make sure to put some pressure on the tail light itself so it does not fall out when you unscrew it.
    • Unscrew the three plastic wing nuts located behind the tail lights.
    Vraag FixBot
  3. 1997-2003 Chevrolet Malibu Tail Lights Replacement: stap 3, afbeelding 1 van 1
    • When the tail light assembly comes loose, do not fully remove it because it may damage the connected wires.
    • Carefully pull the tail light away from the car to expose the connected wires.
    Vraag FixBot
  4. 1997-2003 Chevrolet Malibu Tail Lights Replacement: stap 4, afbeelding 1 van 3 1997-2003 Chevrolet Malibu Tail Lights Replacement: stap 4, afbeelding 2 van 3 1997-2003 Chevrolet Malibu Tail Lights Replacement: stap 4, afbeelding 3 van 3
    • Unclip the rear panel of the tail light assembly. There are two clips on the top and two on the bottom.
    • Remove the rear panel from the rest of the assembly.
    Vraag FixBot
  5. 1997-2003 Chevrolet Malibu Tail Lights Replacement: stap 5, afbeelding 1 van 1
    • Do not pull on the bulb, handle it gently because it is fragile.
    • Grab the plastic base of the bulb and gently wiggle it free.
    Vraag FixBot
  6. 1997-2003 Chevrolet Malibu Tail Lights Replacement: stap 6, afbeelding 1 van 1
    • When handling the new bulbs, avoid touching the glass as much as possible because this can reduce the life of the bulb.
    • Gently push the new bulb into the plastic housing.
    Vraag FixBot
  7. 1997-2003 Chevrolet Malibu Tail Lights Replacement: stap 7, afbeelding 1 van 1
    • After putting the new bulbs in, turn the desired lights on to check that the newly installed bulbs work correctly.
    • These bulbs have different functions including blinkers, brake lights, hazard lights, and back-up lights. They will only turn on when the necessary signal is sent.
    Vraag FixBot
Conclusie
4 andere personen hebben deze handleiding voltooid.
Sank Yang
484 Reputatie
5 handleidingen geschreven
Cal Poly, Team 9-15, Amido Fall 2012 Lid van Cal Poly, Team 9-15, Amido Fall 2012
CPSU-AMIDO-F12S9G15
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 89
Altijd: 20,327
