Ga door naar hoofdinhoud
1997-2003 Chevrolet Malibu Fluid Check
Wat je nodig hebt
  1. 1997-2003 Chevrolet Malibu Fluid Check, Brake Fluid: stap 1, afbeelding 1 van 3 1997-2003 Chevrolet Malibu Fluid Check, Brake Fluid: stap 1, afbeelding 2 van 3 1997-2003 Chevrolet Malibu Fluid Check, Brake Fluid: stap 1, afbeelding 3 van 3
    • Use caution while handling brake fluid. Brake fluid strips paint and dissolves plastic.
    • There is a maximum fluid line on the right side of the reservoir. Remove the brake fluid cap and fill the brake fluid to the maximum level line.
    Vraag FixBot
    Voeg opmerking toe
  2. 1997-2003 Chevrolet Malibu Fluid Check, Power Steering Fluid: stap 2, afbeelding 1 van 3 1997-2003 Chevrolet Malibu Fluid Check, Power Steering Fluid: stap 2, afbeelding 2 van 3 1997-2003 Chevrolet Malibu Fluid Check, Power Steering Fluid: stap 2, afbeelding 3 van 3
    • Do not overfill the power steering fluid reservoir, as this can overwork the power steering pump and cause it to burn up.
    • Remove the power steering fluid cap. Check the fluid level using the dipstick attached to the cap.
    • Fill the power steering fluid to the appropriate level indicated by the "H" for hot and the "C" for cold.
    • If the car has not been started then the fluid is cold. If the engine has been running for five minutes or more, then it is hot.
    Vraag FixBot
    Voeg opmerking toe
  3. 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil: stap 3, afbeelding 1 van 3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil: stap 3, afbeelding 2 van 3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil: stap 3, afbeelding 3 van 3
    • Use the yellow handled oil dipstick to check the oil level by removing the dipstick, wiping off the oil, and re-inserting it.
    • Remove the dipstick again and check the oil level. Full level is read on the right side of the dipstick.
    Vraag FixBot
    Voeg opmerking toe
  4. 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil Continued: stap 4, afbeelding 1 van 3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil Continued: stap 4, afbeelding 2 van 3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil Continued: stap 4, afbeelding 3 van 3
    • If the oil level is below full, add oil to the car by removing the cap labeled "Engine Oil."
    • Add a small amount of oil and repeat Step 3 until the oil level is full.
    Vraag FixBot
    Voeg opmerking toe
  5. 1997-2003 Chevrolet Malibu Fluid Check, Radiator Coolant Resrvoir: stap 5, afbeelding 1 van 3 1997-2003 Chevrolet Malibu Fluid Check, Radiator Coolant Resrvoir: stap 5, afbeelding 2 van 3 1997-2003 Chevrolet Malibu Fluid Check, Radiator Coolant Resrvoir: stap 5, afbeelding 3 van 3
    • Make sure the engine is cool before removing the radiator reservoir cap. Radiator coolant needs to be disposed of properly. Visit this link for more information http://www.epa.gov/osw/conserve/material...
    • Remove the radiator reservoir cap and fill it with coolant until it reaches the full level indicator line on the front side of the reservoir.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Sank Yang
484 Reputatie
5 handleidingen geschreven
Cal Poly, Team 9-15, Amido Fall 2012 Lid van Cal Poly, Team 9-15, Amido Fall 2012
CPSU-AMIDO-F12S9G15
4 Leden
5Gids Commentaar
GM does not want purchasers of used cars to check transmission fluid levels.
Hoping you run it dry so things blow up and you have to buy a new vehicle.
Beginning to dislike GMs
Randy Oman - Antwoord Deel
I been trying to figure out why the cars shaking so i changed the spark plugs now it shake small kind now the airfilrt needs to be changed out as well but whats with the gas smell when turning on?
Bruce allen - Antwoord Deel
I am trying to change my starter on my 1997 Malibu Chevrolet SD 2.1L but I am not sure if I can take it out from the top or it's best to go from the bottom? Need to know ASAP.
Renee Howington - Antwoord Deel
I have a 99 Chevy Malibu what type of starter would work on my car
hernandezchina.1979 - Antwoord Deel
Cómo saber el nivel de aceite de transmisión automática Malibú 99 que no está ala vista o como se checa gracias me urge
Javier Javy - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 82
Altijd: 44,678
