Ga door naar hoofdinhoud
1997-2003 Chevrolet Malibu Air Filter Replacement
Wat je nodig hebt
  1. 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: stap 1, afbeelding 1 van 2 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: stap 1, afbeelding 2 van 2
    • The air filter housing is located on the driver side of the car.
    • Loosen the four housing screws on the plastic air intake box.
    • Do not try to remove these screws from the intake box, as they are not designed to be removed.
  2. 1997-2003 Chevrolet Malibu Air Filter Replacement: stap 2, afbeelding 1 van 2 1997-2003 Chevrolet Malibu Air Filter Replacement: stap 2, afbeelding 2 van 2
    • Loosen the hose-clamp on the air intake tube located on the side of the air intake box.
    • Remove the air intake tube from the intake box.
  3. 1997-2003 Chevrolet Malibu Air Filter Replacement: stap 3, afbeelding 1 van 1
    • Gently lift the top off of the air intake box.
  4. 1997-2003 Chevrolet Malibu Air Filter Replacement: stap 4, afbeelding 1 van 1
    • Remove the air filter from the housing and inspect it.
    • If it can not be cleaned, then it should be replaced with a new one.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Sank Yang
484 Reputatie
5 handleidingen geschreven
Cal Poly, Team 9-15, Amido Fall 2012 Lid van Cal Poly, Team 9-15, Amido Fall 2012
CPSU-AMIDO-F12S9G15
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 40
Altijd: 5,513
