Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two screws securing the upper edge of the knee bolster.
Pull the upper edge down to give access to the underside of the steering wheel.
Remove the lower steering column trim mounting screw.
Remove the lower steering column trim.
Completely loosen the two T30 Torx screws behind the steering wheel while supporting the airbag unit from the front.
Lift the airbag unit up and away from the steering wheel.
Disconnect the orange harness connector from the rear of the airbag unit.
The airbag should now be free to be removed.
