Ga door naar hoofdinhoud
1991-1996 Toyota Camry Oil and Oil Filter Replacement
Wat je nodig hebt
Video overzicht
  1. 1991-1996 Toyota Camry Oil and Oil Filter Replacement, Oil and Oil Filter: stap 1, afbeelding 1 van 1
    • Locate the oil filter under the exhaust manifold in the front of the vehicle
    • source.
  2. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 2, afbeelding 1 van 1
    • Place the Lisle 63600 Oil Filter Tool over the filter, use an extension on the ratchet to reach around the hot manifold, and loosen the filter
    • source
    • Be careful not to burn yourself on the hot manifold.
  3. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the oil filter and let it drain into the oil drain pan
    • source
    • Make sure the pan is aligned to catch oil from both the filter and drain plug.
  4. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the old oil filter
    • source.
  5. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 5, afbeelding 1 van 3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 5, afbeelding 2 van 3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 5, afbeelding 3 van 3
    • Clean the mating surface where the new filter will be installed
    • Ensure there are no old seals or debris that could affect the new filter's seal
    • source.
  6. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 6, afbeelding 1 van 1
    • Install the new oil filter by hand tightening it
    • source.
  7. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 7, afbeelding 1 van 2 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 7, afbeelding 2 van 2
    • Move to the oil drain plug location and remove it using the 14mm socket and ratchet
    • source
    • Let the oil drain into the pan
    • source.
  8. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 8, afbeelding 1 van 1
    • Replace the old gasket on the drain plug with a new one, if necessary
    • source.
  9. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 9, afbeelding 1 van 2 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 9, afbeelding 2 van 2
    • Tighten the drain plug using the 14mm socket
    • source
    • Clean up any excess oil
    • source.
  10. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 10, afbeelding 1 van 3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 10, afbeelding 2 van 3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: stap 10, afbeelding 3 van 3
    • Refill the engine with 5W-30 oil using a funnel
    • source
    • This engine should take about five quarts
    • source
    • Be careful when filling the oil, as there is a plate just under the fill opening that can cause spills
    • source
    • Tilt the funnel to ensure the oil goes into the engine
    • source.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
eCuration
376.693 Reputatie
234 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.718 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 45
Altijd: 9,786
