Ga door naar hoofdinhoud
1986-1993 Volvo 240 Spark Plug Wires Replacement
Wat je nodig hebt
  1. 1986-1993 Volvo 240 Spark Plug Wires Replacement, Spark Plug Wires: stap 1, afbeelding 1 van 1
    • To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
    • Disconnect the spark plug wire from the distributor cap by pulling it straight up.
  2. 1986-1993 Volvo 240 Spark Plug Wires Replacement: stap 2, afbeelding 1 van 2 1986-1993 Volvo 240 Spark Plug Wires Replacement: stap 2, afbeelding 2 van 2
    • Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
    • When installing your new spark plug wires, it's a good idea to apply dielectric grease to the spark plug boots to prevent the electrical connections from being damaged by water or debris.
Conclusie
Install your new spark plug wires in the same manner that you removed the old ones.
David Hodson
150.503 Reputatie
127 handleidingen geschreven
2 opmerkingen
Doing this today. Thanks for the clear, reassuring steps to get it done :)
jeconnol - Antwoord
These directions were great! Thank you. I got the wires on in about 40 minutes. Oh, and I’m a girlie girl. :)
Nancy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 4,019
