Inleiding
A dirty or broken distributor cap may lead to a number of ignition problems in your Volvo 240. Consult your owner's manual for a regular interval to inspect your distributor cap for damage, excess wear, or carbon buildup.
Onderdelen
  1. The distributor cap is located next to the engine and has all of the spark plug wires connecting to it. Pull straight up on the ignition coil wire in the center of the distributor cap to disconnect it.
    • The distributor cap is located next to the engine and has all of the spark plug wires connecting to it.
    • Pull straight up on the ignition coil wire in the center of the distributor cap to disconnect it.
  2. Connect the spark plug wires to the new distributor cap one at a time. Mixing up the order will result in the engine not firing properly or at all. Pull straight up on the boot of the first spark plug wire to disconnect it from the distributor cap. Be sure to pull on the boot and not the wire itself. Spark plug wires are quite fragile and may break easily.
    • Connect the spark plug wires to the new distributor cap one at a time. Mixing up the order will result in the engine not firing properly or at all.
    • Pull straight up on the boot of the first spark plug wire to disconnect it from the distributor cap.
      • Be sure to pull on the boot and not the wire itself. Spark plug wires are quite fragile and may break easily.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. Install the spark plug wire onto the new distributor cap and make sure it is seated properly. Continue to transfer each spark plug wire to the new distributor cap, maintaining the same arrangement of wires on the cap. Once all of the spark plug wires have been installed on the new distributor cap, set the cap aside.
    • Install the spark plug wire onto the new distributor cap and make sure it is seated properly.
    • Continue to transfer each spark plug wire to the new distributor cap, maintaining the same arrangement of wires on the cap.
    • Once all of the spark plug wires have been installed on the new distributor cap, set the cap aside.
  5. Use a flathead screwdriver to release the clip securing the distributor cap. Only one side of the distributor cap has a spot for the clip to rest. The new cap must be installed in the same orientation.
    • Use a flathead screwdriver to release the clip securing the distributor cap.
      • Only one side of the distributor cap has a spot for the clip to rest. The new cap must be installed in the same orientation.
    • Remove the old distributor cap.
    • When installing the new distributor cap, don't forget to reconnect the center ignition coil wire.
Conclusie
David Hodson
133.500 Reputatie
127 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 4
Afgelopen 30 Dagen: 27
Altijd: 4,605
