Ga door naar hoofdinhoud
1985-1988 Volvo 740 Tire Rotation
Wat je nodig hebt
  1. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Front Wheels: stap 1, afbeelding 1 van 1
    • Turn car off and remove keys from ignition.
    • Place car in park (automatic) or neutral (manual).
    • Engage parking brake.
  2. 1985-1988 Volvo 740 Tire Rotation: stap 2, afbeelding 1 van 1
    • Use hydraulic jack on frame of car to raise car.
    • Place jack head underneath frame of car.
    • Only necessary to jack the car until the wheels are just off the ground.
  3. 1985-1988 Volvo 740 Tire Rotation: stap 3, afbeelding 1 van 1
    • Place jack stand on frame of car and remove jack.
    • Do no work under car supported only by hydraulic jack, serious injury or death may occur.
  4. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Rear Wheels: stap 4, afbeelding 1 van 1
  5. 1985-1988 Volvo 740 Tire Rotation: stap 5, afbeelding 1 van 2 1985-1988 Volvo 740 Tire Rotation: stap 5, afbeelding 2 van 2
    • Place jack head underneath frame couple (pictured).
  6. 1985-1988 Volvo 740 Tire Rotation: stap 6, afbeelding 1 van 2 1985-1988 Volvo 740 Tire Rotation: stap 6, afbeelding 2 van 2
    • Do not work under car supported only by hydraulic jack, serious injury or death may result.
  7. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: stap 7, afbeelding 1 van 2 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: stap 7, afbeelding 2 van 2
    • Pry off the all four hub caps by placing a small flathead screwdriver between hubcap and rim pulling the screwdriver away from tire.
    • Pull hubcaps away from tires.
  8. 1985-1988 Volvo 740 Tire Rotation: stap 8, afbeelding 1 van 1
    • Loosen each of the five lug nuts on all tires by turning them counter-clockwise with a 19mm wrench.
  9. 1985-1988 Volvo 740 Tire Rotation: stap 9, afbeelding 1 van 1
    • Remove tires by pulling directly away from car exposing brake rotors.
  10. 1985-1988 Volvo 740 Tire Rotation: stap 10, afbeelding 1 van 1
    • Swap tires according to diagram.
  11. 1985-1988 Volvo 740 Tire Rotation: stap 11, afbeelding 1 van 1
    • Place tires on axels.
    • Hand tighten the lug nuts with narrow end of nut towards car.
    • Finish tightening the lug nuts with 19mm Torque Wrench to a torque of 63 lb*ft.
Conclusie
Garrett Van Ruiten
54 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-28, Regan Fall 2010 Lid van Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 2,636
