Ga door naar hoofdinhoud
1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement
Wat je nodig hebt
  1. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement, Tire Tube: stap 1, afbeelding 1 van 3 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement, Tire Tube: stap 1, afbeelding 2 van 3 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement, Tire Tube: stap 1, afbeelding 3 van 3
    • Shift the bike into the smallest gear.
    • Move the gear levers up to the highest position.
    • Move the bike pedals forward with your hands or ride the bike to make sure the gears change.
    • The bike should make a clicking noise and the chain should shift to the smallest gear.
    • Make sure that the chain has a lot of slack.
  2. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 2, afbeelding 1 van 1
    • Place the bike upside down.
    • Placing the bike upside down is important when doing maintenance on a bike because it keeps the bike stable and easy to work with.
  3. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 3, afbeelding 1 van 3 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 3, afbeelding 2 van 3 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 3, afbeelding 3 van 3
    • Potential for device damage: When the tire is removed DO NOT engage the brakes because they can become stuck together.
    • Caution: When feeding the chain, be sure not to get your fingers caught between the gears.
    • Remove the nuts and bolts.
    • If you are having trouble loosening the nuts, use a rag to move the 15mm wrench.
    • Feed the chain by rotating the wheel and move the chain away from the gear.
    • Pull out the back wheel and make sure the chain remains attached to the frame of the bike.
  4. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the tire valve.
    • Push down with the end of the tire lever to deflate the tire.
    • Deflating the tire makes it significantly easier to remove the tubing later.
  5. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 5, afbeelding 1 van 2 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 5, afbeelding 2 van 2
    • Loosen the tire using a tire lever.
    • If your tires are in bad condition, small fragments of rubber may fall out of the rims.
    • Push the tire lever into the crease of where the metal meets the rubber of the tire.
    • Push the lever along the crease of the tire.
  6. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 6, afbeelding 1 van 3 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 6, afbeelding 2 van 3 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 6, afbeelding 3 van 3
    • Place the wheel on a small rag to prevent scratching the rims.
    • Pull out the tubing.
    • Depending on the condition of your bike, the tubing may be difficult to pull out at first.
    • Remove the valve from the rim by pushing it down into the hole.
    • Remove the tubing.
  7. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 7, afbeelding 1 van 2 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 7, afbeelding 2 van 2
    • Place the new tube over the bike rims.
    • You should be able to easily insert the deflated tubing back into the creases of the tire.
    • Look for the small hole in the rims.
    • Insert the valve.
    • Insert the rest of the tubing.
    • Tuck the tires back into the rims.
    • If you’re having trouble tucking the tire back in, try using the tire lever to tuck the tires back into place.
  8. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 8, afbeelding 1 van 3 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 8, afbeelding 2 van 3 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 8, afbeelding 3 van 3
    • Inflate the new tire.
    • Inflating the new tire before placing it back on the wheel is important. It makes imperfections visible and easily correctable.
    • Insert the end of the bicycle pump into the valve of the new tire valve.
    • Lock the pump into place using the lever at the end of the pump.
    • Pump the tire until the pump reads roughly 75 psi.
  9. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 9, afbeelding 1 van 3 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 9, afbeelding 2 van 3 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 9, afbeelding 3 van 3
    • Attach the back wheel onto the bike.
    • This step is vital because the wheel could fall off if not properly attached. The tire and frame may also grind together and damage the tire.
    • Feed the chain back onto the pedal gear and the back-wheel gears.
    • Straighten out the tire with the blunt end of the hammer.
    • Tighten the nuts and washers using the 15mm sprocket wrench on one side and the 15mm wench on the other.
    • Tightening both bolts at the same time ensures that the tire is straight.
  10. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: stap 10, afbeelding 1 van 1
    • Flip the bike back over.
    • Congratulations, you've successfully replaced the tubing!
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 735
