Ga door naar hoofdinhoud
OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode
  1. OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode, Plug the device into a computer: stap 1, afbeelding 1 van 2 OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode, Plug the device into a computer: stap 1, afbeelding 2 van 2
    • Clearing a unknown password while keeping the data intact is beyond the scope of this guide.
    • Plug your device into your computer. Use the correct cable for your device.
    At this point it's coming in my computer: itune couldn’t connect to iPod because it's locked with a passcode.
    any idea how to solve that?
    Mer - Antwoord
    That’s normal. Put the device in recovery mode and it will not have that problem. Just bear in mind you won’t be able to do a backup of your data.
    Nick -
  2. OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode, Mount the device in iTunes: stap 2, afbeelding 1 van 1
    • Some devices and firmware do not show up in iTunes while locked with a password. This is expected.
    • Since this is a used device, the previous owner's name has been blurred.
    • Once the device is plugged in, verify it shows up in iTunes. The device will not sync while it is locked, but this is expected.
  3. OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode, Reset the device: stap 3, afbeelding 1 van 2 OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode, Reset the device: stap 3, afbeelding 2 van 2
    • Reset the device. Hold both the power and home buttons down at the same time. Do this until the device screen turns black.
    • This is the power button.
    • This is the home button.
  4. OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode, Put the device in recovery mode: stap 4, afbeelding 1 van 2 OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode, Put the device in recovery mode: stap 4, afbeelding 2 van 2
    • This screen may vary based on the version of iOS and device model. Some show the iTunes icon, while others show a computer.
    • Once the Apple logo shows up on the screen, let go of the power button. Hold the home button until the recovery mode screen comes up.
  5. OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode, Restore the device: stap 5, afbeelding 1 van 3 OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode, Restore the device: stap 5, afbeelding 2 van 3 OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode, Restore the device: stap 5, afbeelding 3 van 3
    • If you have done the previous steps correctly, the device will show in iTunes, but prompt it is in recovery mode.
    • Click Restore iPod/iPhone/iPad and then Restore and Update. Agree to the EULA.
    • Once you agree to the EULA (not shown), iTunes will download the latest firmware. Your device will be restored once this is finished.
  6. OBSOLETE - *Pre iPhone 7/7th Gen Touch* How to access Recovery Mode, Set up the device: stap 6, afbeelding 1 van 1
    • Restoring from a backup is NOT recommended. These backups may contain also contain a password, which will force you to repeat this procedure. Delete all existing backups known to have the passcode once restored.
    • Once the device is restored, set it up as a new device. Make a new backup to use moving forward.
Eindstreep
35 andere personen hebben deze handleiding voltooid.
Nick
88.431 Reputatie
49 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.506 handleidingen geschreven
10 opmerkingen
So what happens when this dosen't work?
Ashanti Lewis - Antwoord
you are a life saver!!!! thank you so much!
laranishino - Antwoord
This worked. You must continue to hold the home and power button until the apple logo shows up. Once it shows up, hold the home key. Your iTunes will then have a couple prompts.
Ross Kellman - Antwoord
A couple days ago, I bought myself a used iPhone 3G for $25. It didn’t have a SIM card, but I was able to connect it to my MacBook Pro, fire up iTunes, and basically load the same songs that are on my iPod on it. I was even able to download and install an app I had downloaded from the programmer’s website a few years ago I was sure hadn’t been updated.
All good so far … until I decided to add a password, and then decided that maybe updating the phone’s OS might be a good idea. The password was the same as that of my iPod … but after the update, suddenly I “typed in the wrong pass code.”
After fighting with that for a few hours, I did the restore bit … but now, since there is no SIM card (did I mention I have three phones? No need for another), I can’t get back to where I was before the stupid software update and now I have a phone I can’t use for the purpose for which I bought it.
Thanks, Apple.
That said, any ideas on how to get past that SIM card issue?
G.D. Warner - Antwoord
Okay, so I got on eBay and bought a SIM card “for testing purposes” for about three bucks. It may or may not work, but it should at least get me past the “Dude. You Need a SIM Card” error.
We’ll see how that goes.
G.D. Warner -
Good news! Got a SIM card. Bad news: It was too small to fit into the holder in the phone.
After a quick trip to my local T-Mobile store, I had an adapter — which, I just discovered, I probably could have made myself, according to this article:
Create a Micro-SIM to SIM Adapter
Alas, the SIM card I stuck in there was identified as not being one of the phone’s supported carriers … so we’ll see.
I have a 8+ n it has a activation lock don’t it since I was scammed so help me so I can use it or sell it
DeiShawna Foust - Antwoord
Apparently I left my second gen iPod Touch on, face down on coffee table, and untouched … for about six months. Today I wanted to check something on it, and when it didn’t power up, I connected it to my MacBook Pro.
Everything seemed to be fine, except I couldn’t set the date or time. Each time I had the time almost correct, the wheel would turn, leaving me with (once again) a date from 1969.
Couldn’t connect to the App Store, because of the system’s date. Google wasn’t much help, so after trying a few things that didn’t work, I came here and sure enough, I’m not the only person that had that problem!
Kudos to the author of that guide!
This worked like a charm. Thanks.
Jason Penner - Antwoord
It work, it was clear, thx a lot !!!
simarclub - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 44
Altijd: 49,169
