Ga door naar hoofdinhoud
(AAA) Cleaning battery leakage (Maxxum 5000/7000)
Wat je nodig hebt
  1. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Change note: stap 1, afbeelding 1 van 2 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Change note: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Essential Electronics Toolkit
    $29.95
    • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
    • If you are interested in a refurbished kit stock levels change frequently but can be found here.
    Vraag FixBot
    Voeg opmerking toe
  2. (AAA) Cleaning battery leakage (Maxxum 5000/7000), An example of a "borderline" cover: stap 2, afbeelding 1 van 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), An example of a "borderline" cover: stap 2, afbeelding 2 van 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), An example of a "borderline" cover: stap 2, afbeelding 3 van 3
    • This is WHY you clean the corrosion - not polish it off. This cover was properly treated, but it still required a wire brush cleanup as well!!!
    • Severe terminal damage (wire brush needed)
    • Had to use sandpaper to fix
    Vraag FixBot
    Voeg opmerking toe
  3. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Unscrew the cover: stap 3, afbeelding 1 van 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Unscrew the cover: stap 3, afbeelding 2 van 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Unscrew the cover: stap 3, afbeelding 3 van 3
    • Unscrew the battery cover from the body. Remove the bad batteries.
    Vraag FixBot
    Voeg opmerking toe
  4. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Remove the battery retention clip: stap 4, afbeelding 1 van 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Remove the battery retention clip: stap 4, afbeelding 2 van 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Remove the battery retention clip: stap 4, afbeelding 3 van 3
    • To thoroughly clean the AAA cover, you must disassemble it. You will not be able to fully clean it assembled.
    • Stick a screwdriver or pry tool in the side with one pin. DO NOT pry on the side with 2; it can break the second pin.
    • LIft up on the clip and remove it. This can be safely cleaned in a vinegar bath.
    Vraag FixBot
    Voeg opmerking toe
  5. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Optional: Pre-clean the cover: stap 5, afbeelding 1 van 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Optional: Pre-clean the cover: stap 5, afbeelding 2 van 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Optional: Pre-clean the cover: stap 5, afbeelding 3 van 3
    • This step will REDUCE the nickel-plating damage, not prevent it.
    • Before cleaning the corossion, use a chemical like denatured alcohol and a disposable toothbrush to clean some of the corrosion. Once this is done, rinse and dry the cover.
    Vraag FixBot
    Voeg opmerking toe
  6. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Battery corrosion neutralization: stap 6, afbeelding 1 van 2 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Battery corrosion neutralization: stap 6, afbeelding 2 van 2
    • If there is any stubborn alkaline on the screw plate, sand the affected tab down until you have a good connection and STOP. The tabs are VERY THIN.
    • With the battery holder disassembled, clean the clip by soaking it in vinegar.
    • If affected, clean the tabs on the screw cover with a toothbrush or Q-Tip.
    Vraag FixBot
    Voeg opmerking toe
  7. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Reassemble the cover: stap 7, afbeelding 1 van 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Reassemble the cover: stap 7, afbeelding 2 van 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Reassemble the cover: stap 7, afbeelding 3 van 3
    • Slide the side with 2 pins in FIRST, then let it rest.
    • Push down to lock the cover in place. Note: You may need to push the plastic on the screw plate back with a pry tool.
    • Put it in the closed position, and check if it opens correctly and accepts batteries.
    Vraag FixBot
    Voeg opmerking toe
  8. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Test the camera: stap 8, afbeelding 1 van 1
    • Install fresh batteries and take a few test shots.
    • If it works, shoot on with the old cover if desired and convert later :-).
    • If the camera is still dead, try a known good cover, or buy a used one with no existing corrosion, and re-assess the camera.
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
Nick
103.384 Reputatie
68 handleidingen geschreven
Master Techs Lid van Master Techs
Community
333 Leden
1.485 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 73
Altijd: 1,121
