Inleiding
If your back panel is cracked or you wish to change the color with one you found online here is the guide you are looking for! Be sure to turn off the camera and remove the battery before you begin the replacement.
  1. Locate the bottom panel of the camera.
    • Locate the bottom panel of the camera.
    • Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
    • Push the screwdriver firmly into the screw so that the driver will not strip the screw.
  2. Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver. Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
    • Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
  3. Pry open the back panel using the metal spudger. Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera.  Do not jam the tool in this part or the ribbon will rip.
    • Pry open the back panel using the metal spudger.
    • Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera. Do not jam the tool in this part or the ribbon will rip.
  4. Open the two halves of the camera, taking care not to disturb the ribbon cable. Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the  next step
    • Open the two halves of the camera, taking care not to disturb the ribbon cable.
    • Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the next step
  5. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  6. Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger. Push the ribbon out of its socket with the plastic opening tool. Push the ribbon out of its socket with the plastic opening tool.
    • Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger.
    • Push the ribbon out of its socket with the plastic opening tool.
  7. Completely separate the back panel from the camera. Completely separate the back panel from the camera.
    • Completely separate the back panel from the camera.
  8. Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver. Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
    • Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
  9. Lift up the grey tab on the ZIF connector with the spudger to remove the ribbon. Using both thumbs push the ribbon out of the ZIF connection. Using both thumbs push the ribbon out of the ZIF connection.
    • Lift up the grey tab on the ZIF connector with the spudger to remove the ribbon.
    • Using both thumbs push the ribbon out of the ZIF connection.
  10. Use the metal spudger to pick the bottom of the plastic piece while simultaneously using your index finger to push down on the larger metal slab. This will cause the metal plate with the large ribbon to slide down and out of the plastic back panel.
    • Use the metal spudger to pick the bottom of the plastic piece while simultaneously using your index finger to push down on the larger metal slab. This will cause the metal plate with the large ribbon to slide down and out of the plastic back panel.
    • Do not disconnect the blue ribbon.
  11. Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs. Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs. Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs.
    • Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs.
  12. Separate the back panel from the LCD. Separate the back panel from the LCD.
    • Separate the back panel from the LCD.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Greg Baghdikian
143 Reputatie
1 Handleiding geschreven
Cal Poly, Team 20-13, Maness Winter 2015 Lid van Cal Poly, Team 20-13, Maness Winter 2015
CPSU-MANESS-W15S20G13
4 Leden
7 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 25
Altijd: 883
