Ga door naar hoofdinhoud
Sony WF-1000XM4 Wireless Earbuds battery replacement
Wat je nodig hebt
  1. Sony WF-1000XM4 Wireless Earbuds battery replacement, Prepare earbud opening: stap 1, afbeelding 1 van 1
    • Before beginning this repair, make sure you have completely discharged the battery of the earbud you wish to open. To do this, leave the earbud out of its charging case until the battery is completely discharged.
    • This is a safety precaution to avoid the battery exploding in case of an unintentional short circuit or if too much heat is applied in step 3.
  2. Sony WF-1000XM4 Wireless Earbuds battery replacement, Remove ear tip: stap 2, afbeelding 1 van 2 Sony WF-1000XM4 Wireless Earbuds battery replacement, Remove ear tip: stap 2, afbeelding 2 van 2
    • Pull on foam ear tip to remove it.
  3. Sony WF-1000XM4 Wireless Earbuds battery replacement, Heat earbud: stap 3, afbeelding 1 van 1
    • Using a powerful hair dryer or a heat gun, heat the earbud for about ten seconds to soften the glue that sticks both parts of the earbud together.
    • Careful: if you heat the earbud too much, the plastic shell may distort.
    • Heat the earbud all around.
    • This is a difficult step because you need to heat the earbud enough to soften the glue inside the earbud without burning the plastic of the earbud’s shell.
  4. Sony WF-1000XM4 Wireless Earbuds battery replacement, Open the earbud shell: stap 4, afbeelding 1 van 2 Sony WF-1000XM4 Wireless Earbuds battery replacement, Open the earbud shell: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Jimmy
    $7.95
    • Take the thinnest possible tool, and slide it into the gap between the two parts of the earbud’s shell.
    • Then, start to lever the two halves apart at the point circled in the picture.
    • If the two parts don’t separate, you’ll need to heat the earbud a little more.
    • When the two parts of the earbud’s shell start to separate, continue to separate them by levering all around the shell.
    • Careful not to burn your fingers as the earbud will be very hot.
    • In the picture I used the iFixit’s Jimmy opening tool, but I think the iFixit’s iFlex Opening Tool is better because it is thinner so it might make this step a bit easier.
  5. Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug board-to-board connector: stap 5, afbeelding 1 van 3 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug board-to-board connector: stap 5, afbeelding 2 van 3 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug board-to-board connector: stap 5, afbeelding 3 van 3
    • Once the earbud is open, you will see two tiny circuit boards linked by a board-to-board connector.
    • Using an Opening Pick, unplug the two circuit boards by levering very gently between them.
    • Caution: Do not use a metal tool for this step, as the battery is still inside the earbud and you may unintentionally short-circuit components as they are still powered.
    • Set the upper part of the earbud shell aside in order to reassemble it later.
    • The upper part is highlighted in red in the third picture.
    • The lower part is highlighted in dark blue in the third picture.
  6. Sony WF-1000XM4 Wireless Earbuds battery replacement, Unlock the ZIF connector on the lower part circuit board: stap 6, afbeelding 1 van 3 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unlock the ZIF connector on the lower part circuit board: stap 6, afbeelding 2 van 3 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unlock the ZIF connector on the lower part circuit board: stap 6, afbeelding 3 van 3
    • Locate the ZIF connector on the lower part circuit board.
    • If there is enough room, the battery may be removed without disconnecting the ZIF connector, making this delicate and difficult step obsolete
    • Lift the flap of the ZIF connector using an Opening Pick or another thinner plastic tool.
    • Careful: Do not use a metal tool for this step.
  7. Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug the cable of the ZIF connector: stap 7, afbeelding 1 van 3 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug the cable of the ZIF connector: stap 7, afbeelding 2 van 3 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug the cable of the ZIF connector: stap 7, afbeelding 3 van 3
    • Using an Opening Pick or a spudger, gently unstick the glued cable.
    • Then, gently unplug this cable.
    • It may be a bit difficult to unplug. Take your time, and don’t force it. The cable is fragile.
  8. Sony WF-1000XM4 Wireless Earbuds battery replacement, Unstick circuit board from the battery: stap 8, afbeelding 1 van 3 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unstick circuit board from the battery: stap 8, afbeelding 2 van 3 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unstick circuit board from the battery: stap 8, afbeelding 3 van 3
    • Find the junction between the electronic circuit and the earbud battery just below it.
    • Using an Opening Pick or a very thin plastic tool, very gently unstick the circuit board from the battery by inserting the Opening Pick between the circuit board and the battery.
    • The circuit board sticks directly to the negative battery terminal with adhesive.
    • Caution: There is a tiny metal contact under the circuit board that makes contact with the battery. Unstick the circuit board gently to avoid damaging this contact.
    • Do not use metal tools in this step as you may short-circuit the battery.
    • Once the circuit board is unstuck from the battery, lift it up as shown on the third picture to have enough space to remove the battery.
  9. Sony WF-1000XM4 Wireless Earbuds battery replacement, Remove the battery: stap 9, afbeelding 1 van 2 Sony WF-1000XM4 Wireless Earbuds battery replacement, Remove the battery: stap 9, afbeelding 2 van 2
    • Remove the battery by lifting it up using the point of a spudger as shown on the first picture.
    • A bit of force might be required here as the battery is glued to the underside with adhesive.
  10. Sony WF-1000XM4 Wireless Earbuds battery replacement, Lift the metal contacts: stap 10, afbeelding 1 van 2 Sony WF-1000XM4 Wireless Earbuds battery replacement, Lift the metal contacts: stap 10, afbeelding 2 van 2
    • Find the two metal contacts
    • One highlighted in red.
    • One highlighted in dark blue.
    • If the contacts were flattened during the battery removal, very carefully lift them up a bit with the point of tweezers so that they will make good contact with the new battery when you reassemble the earbud.
  11. Sony WF-1000XM4 Wireless Earbuds battery replacement, Install new battery: stap 11, afbeelding 1 van 3 Sony WF-1000XM4 Wireless Earbuds battery replacement, Install new battery: stap 11, afbeelding 2 van 3 Sony WF-1000XM4 Wireless Earbuds battery replacement, Install new battery: stap 11, afbeelding 3 van 3
    • Install the new battery by placing it in the earbud, negative terminal up.
    • This step can be tricky, as the battery may be attracted by the magnet in the earbud when it is being inserted into the slot.
    • The first picture shows the positive side of the battery.
    • The second picture shows the negative side of the battery.
    • The third picture shows the new battery installed inside the earbud.
Conclusie
To reassemble your earbud, follow these instructions in reverse order from step 8, then glue the two parts of the earbud using E-8000 glue when resealing it.
E-8000 glue is a glue that remains transparent and doesn’t leave drying residues.
221 andere personen hebben deze handleiding voltooid.
Brendan
51.915 Reputatie
3 handleidingen geschreven
98 opmerkingen
I needed to perform the reinitialization procedure to get the headphones to work together after, but apart from that it worked well!
Rasmy Samy - Antwoord
Good point, thanks, I completely forgot to write a conclusion about this :-)
Hard reset the earbuds will reset battery stats stored inside the earbuds internal memory, it's essential for earbuds to works well with new batteries.
Brendan -
When replacing batteries in the XM4 it is essential to use 3.85v 75mAh batteries.
Unfortunately, some battery sellers are incorrectly indicating that 3.7v batteries can be used.
JNavas - Antwoord
Thanks for the heads up. I just checked the batteries I got from Ebay and Indeed got sent Z55 instead of Z55H ( even though the listing said I was buying Z55H batteries.
marconorton -
I understand for the voltage but why couldnt you use a battery with more capacity? That seems like it would be an upgrade (if you could find some that fit obviously)
Ragnarok Del -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 420
Afgelopen 7 dagen: 3,248
Afgelopen 30 dagen: 13,381
Altijd: 351,462
