Inleiding
你Apple Watch里的电池坏掉了或是鼓包了吗?跟着我们的指南来更换一个新的电池。
提醒:如果你的电池鼓包了, 您需要采取适当的预防措施。
Wat je nodig hebt
准备一个 iOpener (或者拿一个电吹风机或热风枪),将加热过的 iOpener 放在表的正面,直到它摸起来稍微有点烫。
将你的 iOpener 留在上面至少一分钟,使得屏幕充分受热并软化粘合剂。
想要将你的设备重新装好,请从第17步开始按照Force Touch传感器指南来重新组装你的手表并且完成修理。
361 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
30 opmerkingen
I did a battery replacement in a 38mm Series 1 iwatch and the darn battery is not charging properly. It's been on the charger about 3 hours and I'm only at 14%. Any suggestions?
I managed to replace a swollen battery ($33.25 on amazon) that popped the screen, but this is not for the faint of heart. Special emphasis needs to be placed on not twisting the digitizer connectors as they are quite fragile ($119.99 on ebay for a new digitizer). It's also easy to damage the force-touch sensor ($24.95 on iFixit). You also need adhesive gaskets ($12.98 for 5 on Amazon)
iFixit lists all the parts required but were out of stock on all but one of the items I needed at the time.
Battery:
https://www.amazon.com/gp/product/B01MV2...
Digitizer:
http://www.ebay.com/itm/262744629522?_tr...
Force Touch Sensor Gasket:
[gekoppeld product ontbreekt of is uitgeschakeld: IF308-013-2]
Adhesive Strips:
Appreciate the detailed steps, happy for the option but after reading the $79 to get Apple to replace vs the $33, plus tools for battery... taking it to Apple Store does not seem so bad.
79 is just for battery …there Will be around 220$ service fees extra !!!
Nope $79 complete. Just had it done at Apple store. Took about 30 minutes.
Albert -
