Ga door naar hoofdinhoud
Video overzicht
Inleiding
本周,苹果更新了其外围输入设备的产品阵容,因此,我们召集了我们可以召集的所有拆卸专家。 到目前为止,我们已经拆解了第二代产品。''
妙控板 2'''
妙控键盘, 现在我们将视线转移到妙控鼠标 2。 这个新的设计能够经历时间的考验吗?快来跟我们一起看看拆解吧!
关注我们,随时了解我们的最新调查。
Twitter, Instagram, or Facebook!
Deze demontage is geen reparatiehandleiding. Om je Magic Mouse 2 te repareren, gebruik onze reparatiehandleidingen.
  1. 这是目前功能最全的鼠标,让我们看看它的规格清单 多点手势触控操作
    • 这是目前功能最全的鼠标,让我们看看它的规格清单
    • 多点手势触控操作
    • 蓝牙无线连接
    • 闪电接口 (充电和配对)
    • 内置锂离子充电电池
  2. 我们可以在FCC标志和Lighting接口之间找到新的型号代码:A1657 看到苹果第一款可以充电的鼠标我们着实很激动-但是我们还是要说,把充电口放在这真的很搞笑。
    • 我们可以在FCC标志和Lighting接口之间找到新的型号代码:A1657
    • 看到苹果第一款可以充电的鼠标我们着实很激动-但是我们还是要说,把充电口放在这真的很搞笑。
    • 有线连接时,妙控鼠标2暂时无法使用,除非您打算将你的额头当鼠标垫来用。
    Apple’s opt-criticized decision to put the lightning port on the bottom makes a lot of sense to me— the clear message here is that when you see “mouse battery low” warnings, plug your mouse in to charge the next time you walk away from your computer— over lunch, or at the end of the day. Since it’s a 2-month-lasting battery and Apple’s low battery predictions are often accurate and give you plenty of time, you really have 2-3 days before it’s dead, so even the most forgetful of users will have multiple chances to plug the thing in overnight.
    But this really seems like an intentional design choice to prevent users from using the mouse with a cable plugged-in permanently. Corded mice almost always have the cable built-in rather than having a female plug for good reason— moving a mouse around can and will put a lot of strain on a plug. So Apple made the decision that rather than warning users not to use the mouse while plugged in for extended periods of time, to make it impossible to use while charging.
    Slipp D - Antwoord
    A few (too many) have griped about the horrible seething pain of not having the freedom to ignore low battery warnings repeatedly and then once it’s dead, use it as a corded mouse for a while. Apple decided that if you choose to ignore all the warnings, you can later let your mouse charge for 2 1/2 hours without using it… but in reality, if you just need a charge to last until the end of the day, a 15-30 minute charge will do the job, and you can charge it the rest of the way over night.
    There have been so many gripes about this from the Apple community, it feels like the Apple-hating 1990s all over again. Here’s the deal— the product works well and gives plenty of leeway. It doesn’t work like your favorite rock-bottom-priced PC accessory, but it also doesn’t instant-die without warning, nor does the internal connector break after a year like that PC accessory. Both build quality and design (in terms of user experience) are responsible for a mouse that’ll last a decade or more.
    Slipp D - Antwoord
  3. 第一眼看上去,新的妙控鼠标(左边)跟他大哥没有什么区别。鼠标兄弟! 但是,当我们翻转过来看背面时,区别一下子就显现出来了。 可充电的妙控鼠标 2放弃了电池盖,并将电池卡口位置变成了新的Lightning接口。
    • 第一眼看上去,新的妙控鼠标(左边)跟他大哥没有什么区别。鼠标兄弟!
    • 但是,当我们翻转过来看背面时,区别一下子就显现出来了。
    • 可充电的妙控鼠标 2放弃了电池盖,并将电池卡口位置变成了新的Lightning接口。
    • 苹果也将印刷的颜色做了更改,并取消了状态LED灯,也许是要跟其他外设进行设计匹配。
    • 这不是我们第一次拆解妙控鼠标了,所以我们知道我们需要请来iOpener.
    • 在上一代妙控鼠标上,粘合剂将铝制机腹和鼠标牢固粘住。 这次我们不想看见这样的情况了。
    • 如果其他“ 妙控”设备教会我们什么,那就是Apple太喜欢它们的粘合剂了。
    Hello!
    What sort of heating manner would you suggest?
    Emile - Antwoord
    esos adhesivos donde los venderan???
    danny garrido - Antwoord
  4. 苹果已经提到他们的鼠标具有“优化的垫脚设计”。 我们认为我们应该剥下这些垫脚就有机会来找到那些藏在下面的新型号螺丝。 我们可以做梦,不是吗? 经过大量的加热和用上了半打撬动工具,我们将鼠标下半部分从下面的胶状混乱中部分拆解了出来。
    • 苹果已经提到他们的鼠标具有“优化的垫脚设计”。 我们认为我们应该剥下这些垫脚就有机会来找到那些藏在下面的新型号螺丝。
    • 我们可以做梦,不是吗?
    • 经过大量的加热和用上了半打撬动工具,我们将鼠标下半部分从下面的胶状混乱中部分拆解了出来。
    • 过了大概一个世纪,我们终于将底壳从鼠标主体上分离了下来,然后看见了(仍然很黏的)中框的结构。
    is the lower casing material now real aluminium or just aluminium looking plastic as it was before?
    mw - Antwoord
    It was NEVER silver painted plastic. Maybe you should have a closer look - VERY thin, hardened aluminium can appear _like_ plastic, but be assured - it's REAL aluminium. This isn't HP here.
    Matt Foot -
    well, having a closer look at my magic mouse 1, all i see is where the shinier silver-colored outer metallic coating has worn away in a splotchy and spotty manner from where my fingers gripped it on both sides; gross. what's underneath looks and feels very much like gray plastic.
    so, is the new 2 a single piece of solid aluminum? really want to know, especially for that price. $80 for a mouse that will need a new battery in 2-3 years AND has it's outer coating disintegrate to human touch is not a good deal.
    PS -
    tuck it guy if u dnt
    do it why, heavens open all day. not headed there why ask
    Mizzie Salazar -
    I’m a little perplexed by this as I have both iterations in front of me. While I only needed my thumbnails to separate the case on both, my Magic Mouse 1 is, without doubt, Aluminum. The Magic Mouse 2 base is just regular silver coloured plastic.
    Stephen Treloar - Antwoord
    Mit dem Wissen, wie und wo die vier Haken sitzen, ist das Öffnen der Maus auch ohne das mühsame Entfernen des Klebers ganz einfach: In den Ecken nacheinander mit einem Spatel unter die Kante des Oberteils fassen, mit dem Spatel das Oberteil seitlich verschieben, so dass der Haken herausspringt. Damit ist das Öffnen eine Sekundensache.
    Matt Schulz - Antwoord
    There is an easier way to taking this apart, if you didnt already know and you are looking to repair one of these this will help. All that needs to be done is to pry the top half along the sides with a flat head screw driver, you should hear a click. Repeat this u till all is off. https://youtu.be/thNxWVfLrr4 here is the video i found for reference, this way is a lot better as you can repair it in a shorter amount of time and it is less damaging
    Lucian - Antwoord
  5. 撬开四个塑料卡扣,使我们能够进入电池仓。 事实证明,这些卡扣实际上是固定顶部和底部之间的锁定结构。
    • 撬开四个塑料卡扣,使我们能够进入电池仓。
    • 事实证明,这些卡扣实际上是固定顶部和底部之间的锁定结构。
    • 检查了透明的丙烯酸涂层。 它仅涂在底面上,而使顶面和侧面都很清新-嗯!
    • 抬起上壳体,我们可以清楚地看到是什么使这款鼠标具有意识,即具有电容的传感阵列。
    • 电容阵列使该鼠标有点像跟触控板的结合体,使其能够检测表面上的触摸,在不移动鼠标的前提下感知手势。
  6. 终于我们看明白了! 螺丝! 不幸的是,他们在排线上按装了一个支架,这暂时阻止了我拆解鼠标头-但是,排线的“安全带”会使鼠标更好地承受跌落所带来的冲击。 最终将鼠标底部分离开来,现在就可以看清楚外壳上的电容式触摸感应阵列。 单击鼠标时,一个小的弹簧会提供一定的阻力并将力分散开来,从而使右侧的小按钮看起来占据了鼠标的整个宽度。 酷!
    • 终于我们看明白了! 螺丝! 不幸的是,他们在排线上按装了一个支架,这暂时阻止了我拆解鼠标头-但是,排线的“安全带”会使鼠标更好地承受跌落所带来的冲击。
    • 最终将鼠标底部分离开来,现在就可以看清楚外壳上的电容式触摸感应阵列。
    • 单击鼠标时,一个小的弹簧会提供一定的阻力并将力分散开来,从而使右侧的小按钮看起来占据了鼠标的整个宽度。
  7. 这个小小的主板看起来很成熟! Broadcom BCM20733增强数据速率型蓝牙3.0单芯片解决方案 未知的303S0499-可能是专有的Apple触摸控制器
    • 这个小小的主板看起来很成熟!
    • Broadcom BCM20733增强数据速率型蓝牙3.0单芯片解决方案
    • 未知的303S0499-可能是专有的Apple触摸控制器
    • 恩智浦1608A1充电IC
    • 德州仪器56AYZ21
    • 意法半导体STM32F103VB 72 MHz 32位RISC ARM Cortex-M3
  8. 隐藏在主板下面,我们找到了一个小开关,就是让鼠标发出咔咔声音的物件(暂时还没有Taptic Engine)。 幸运的是,它仅由上方的板子固定住,欢迎它从沥青坑中蹚过来。 作为鼠标中的常见故障部件,Apple使用了一个相当标准且易于采购的开关,这很令人高兴-尽管要更换它,需要处理所有胶水(并需要焊接)。
    • 隐藏在主板下面,我们找到了一个小开关,就是让鼠标发出咔咔声音的物件(暂时还没有Taptic Engine)。
    • 幸运的是,它仅由上方的板子固定住,欢迎它从沥青坑中蹚过来。
    • 作为鼠标中的常见故障部件,Apple使用了一个相当标准且易于采购的开关,这很令人高兴-尽管要更换它,需要处理所有胶水(并需要焊接)。
  9. 我们将注意力转移到电池上,该电池像一个小塑料盒中躺着的小虫一样紧紧的贴合,烦人。 事实证明,这并不是唯一的问题,而且还有一堆胶水需要解决。 取出电池比我们所担心的还要差。 妙控鼠标 2的电池与Apple TV 遥控器的电池是一致的-Lightning接口焊接到电池的排线上。 嘘
    • 我们将注意力转移到电池上,该电池像一个小塑料盒中躺着的小虫一样紧紧的贴合,烦人。
    • 事实证明,这并不是唯一的问题,而且还有一堆胶水需要解决。 取出电池比我们所担心的还要差。
    • 妙控鼠标 2的电池与Apple TV 遥控器的电池是一致的-Lightning接口焊接到电池的排线上。 嘘
    • 这个小配件不会带来光亮,3.67 V,7.28 Wh,1986 mAh锂离子电池比iPhone 6s相比,多9%的容量!
  10. Magic Mouse 2可修复性得分:2(最容易修复为10) Lighting接口和电池可以被更换(均为独立组件),独立的主板-这些都建立在您能拆开设备的前提下。
    • Magic Mouse 2可修复性得分:2(最容易修复为10)
    • Lighting接口和电池可以被更换(均为独立组件),独立的主板-这些都建立在您能拆开设备的前提下。
    • 更换故障的微动开关需要撬开强力粘合剂和进行焊接。
    • 过度使用强力粘合剂会使拆卸后面板非常困难,从而阻碍了对每个内部组件的维修。
    • 如果没有服务手册,很难在不损坏内部组件(例如光学传感器和电源开关)的情况下拆开鼠标。
Met dank aan deze vertalers:
en zh
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
43 Opmerkingen
Disposable mouse once the battery goes.
rgarjr - Antwoord
hmmm... what was wrong with just replacing batteries?
Now we have a device that has a limited life span of about 2-5 years due to the battery (which can develop faults)....
I dont like Apple purposely creating limit life span products, and using tones of glue to make them difficult to repair - this is not good and quite distrusting of Apple... Steve Jobs would hate all this glue -- what ever happened to good well-built great designed products???
pauldixon1986 - Antwoord
On keyboards, little. On mice, I get through a lot of batteries.
alex -
And there was plenty of glue around in Apple products where SJ was running the show.
98% of these mice will never need repairing outside warranty. That glue makes for a product that is less likely to go wrong.
Of course iFixit doesn't care [in a positive sense] about reliability. They want products that they can sell you a fix for.
alex -
On the contrary, it was after Steve Jobs return to Apple that they moved away from maintanable hardware to gluey messes. And honestly, there's nothing wrong with that. Apple banks on the fact that the vast majority of its customers will accept nigh non-existent repairability in exchange for sleek form factors, and they're absolutely right. That means that the few percent of computer users who value repairability and upgradeability can take their business elsewhere, and honestly, that sort of person wasn't in the market for an overpriced product that's more fashion accessory than it is a tool in the first place.
dbgrogg -
There was a flaw with their battery holder, I always had issues where the batteries wouldn’t make proper contact with the positive end of the AA cell, and disconnect, I fixed the problem with a blob of solder on the contact, but this was a temporary solution to a problem with the design.
Legend Cox -
Guys i have recently purchased this mouse and when i flip it to turn it on i can hear a rattling noise from inside, on further shaking the mouse it feels as if something is loose inside the mouse near the lens hole.
Is that normal ?
mrigankh - Antwoord
seems some guy is also selling a charging dock for these now to combat the terrible charging deisgn http://www.ebay.com/itm/252379999994
alexjankuv - Antwoord
In step 8, photo 2 of the board top there's an unpopulated usb port footprint on the right edge of the board. Looks like they ran a revision with the usb port coming out the front.
Max McLaughlin - Antwoord
You know what? As a repair and service engineer of 25 years, I wouldn't let iFixit ANYWHERE NEAR my Magic Mouse if they think that spinning it around on its back is a good idea - that'll scratch the plastic top shell - WHY WOULD YOU DO THAT, YOU CRAZY PEOPLE? Talk about stupid - that video is just a staff member showing off, trying to make the video "interesting" - well don't - we are not fools.
Matt Foot - Antwoord
Matt you're impractically critical and it sounds like you're insecurely threatened by a company that teaches people how to fix their own stuff versus spending money on you, the bitchy "repair tradesman".
Mike Kormendy -
Your trumped up title does a good job at introducing the rest of you.
scottjoewilliams -
So disappointed that Apple has used Transistor radio technology from 50 years ago. One drop (on carpet) rendered mine useless. I think I'll get the battery cover style mouse to replace. Stupid.
rjgajsek - Antwoord
спасибо большое!!! ваш разбор очень помог мне! вернул к жизни это чудо техники)))
andrey - Antwoord
Guess I'll hold on to my first gen Magic keyboard and mouse rather than the inconvenience of recharging, waiting, and throwing out a less-than-friendly keyboard/mouse set. But i guess if it lasts 3-5 years that's all we can expect. I still prefer consumer-friendly devices though so I'll hold onto my first gen devices as long as I can.
Bob Foss - Antwoord
where can i find those spare black feet
Roshan Sahoo - Antwoord
The battery stopped holding a charge 13 1/2 months after we bought it…out of warranty for 1 1/2 months. Apple initially said tough luck! Took some more complaining to get it a replacement. How can Apple claim to be green when you can’t replace the battery?
carlchizewski - Antwoord
It’s really not the bad to get the battery out, but try to find a replacement not going to happen, So why even do it…
Work - Antwoord
Thank you for your information;
typically I thought that I could open the Magic Mouse without reading any instructions…boy was I wrong! Oh well, I actually prefer Logitech or other cheaper mouses than Apple’s offering anyhow. I’ve been a loyal Apple fan since Apple began. They may be the biggest brand but they got there by royally screwing those who got them there
Bob W.
rkirkwalker88 - Antwoord
Use first version of magic mouse. Use rechargeable batteries. Saves a lot of time. No gimmicks.
Ben Tupper - Antwoord
My father let it sit in a drawer for a year and I fear the Li battery has lost it’s ability to charge. Seems to be a common issue with electronics today. If you leave them discharged for long enough, they won’t charge again. And with these tightly integrated batteries, fixing it becomes a hard sell.
scottjoewilliams - Antwoord
Thanks for your great JOB, i’ve repaired my Magic Mouse 2
luismiquelcompany - Antwoord
You have got to be kidding me with a battery that lasted (3) months.
GUY INFIELD - Antwoord
The proprietary flat cable is soldered to the battery in a manner that no one should try to un-solder it. It’s fun to take apart, but unlikely that mortals could safely un-solder the cable from the battery. A wonderful example of an “unrepairable-by-design” item.
Chris Kimball - Antwoord
I was able to open the MM2 with a spudger - the plastic clips pictured in step 6 were the only thing holding the top on mine. From there I had access to the rest of the internal parts, making it easy to swap the clicker with a silent one. Worked well and was way easier than I thought… No mess with adhesive, not too much fuss with reseating the ribbon. Maybe I just got lucky?
Anthony Lopez - Antwoord
This. Actually the whole process of tearing apart the metal cover with heat is totally not needed. Both halves are kept together with just 4 clips.
karmansan -
Do you have any photos/videos showing how this can be done?
Chris -
no need to remove wear strips on bottom, just twist the top shell off with plastic spudger tool - you can use screw driver but take care not to damage the plastic edges and aluminium bottom half
owen1234321 - Antwoord
I have a Magic Mouse 2 and the onscreen pointer jumps all around the place.
I have looked and got all the cat hair and dust i could - yet it still jumps around.
Please advise:
Patrick DonEgan - Antwoord
There is no need to remove the glued bottom, the mouse pops open relatively easily…..four spots 1.5 inches from the front and back on both sides
petermandt6 - Antwoord
Hello! I have this problem. I click on magic mouse but the key don’t come back and so I can’t click again. Can I or someone repair it? Or do I have to buy another?
Paolo - Antwoord
Hey Paolo, if you pry off the white top using a thick guitar pick or spudger (just use force about 3 cm from the top and end of the device, inside the seams) you can bend up the spring a little bit. This may help. Alternatively, shake and tap the ouse on a table to see if anything falls out.
Laurens -
103/5000
Hi. Magic Mouse 2 fell to the ground, now it does not work. I need help, how can I repair it?
ondina - Antwoord
overpriced but SPLENDID!!! I LOVE APPLE!!!
Yannis - Antwoord
You don’t actually have to contend with any glue when disassembling this mouse. Nor do you need to solder anything. Replacing the battery/port combo could realistically take around 10 minutes for a semi skilled tech.
timfearsatan - Antwoord
Hi iFixit,
Thanks for all your hard work! I have used this to tackle replacing a battery. As you say, it’s NOT easy! I thought I’d let you know I have managed to do it. I found a battery for £21.50. I didn’t bother taking the feet off, I did heat the case with a hair dryer and was attempting to remove the base from the the internal structure, using a few ‘plectrum’ prying leavers … !! but somehow I managed to release a couple of the four clips, I went on to undo the others and it opened! The motherboard does need to come off to get the battery ribbon under it. Out of curiosity I wondered if I could do it again, and I did! There is a knack to it, but it does save the un-gluing! Why so much glue under the battery! it ain’t going anywhere with the tight fitting enclosure around it. I removed all the double sided tape off the new battery before installing it, in case I replace it again in the future. Thanks!! For the cost of the battery I now have a piece of Apple E waste that’s now worth £40-£50!
Best, Gavin
Gavin - Antwoord
mine went TU today, ordered a cheap replacement. we shall see who wins
richard - Antwoord
ain’t this a kick in the cargo pants. my (purchased in 2017) MM2 has sprung to life…dunno what was going on. i pried off the skids and tried lifting the bottom shell with my spongers…but set it side…put the skids back on and pushed it to the side. i had left the bluetooth system pane open, and i saw it listed, it was turned off, so i pushed the switch to on and it now recognised….huzzah for monkey prying!
richard - Antwoord
where can i buy parts?
Rain wav - Antwoord
Apple updated the Magic Mouse 2 in August 2021 and dropped the “2” from the name. I’m not sure what has changed internally, but Apple said it has a longer battery life, so possibly other things have changed internally as well. That could justify a new teardown! (hint: please do)
Joseph Costello - Antwoord
5 Years battery's died. 2/10 to replace. Reverted to ordinary USB mouse which was actually older than the MM2. Apple should be landfill/climate change taxed to death for this kind of product.
Roger - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 56
Afgelopen 7 dagen: 391
Afgelopen 30 dagen: 1,604
Altijd: 190,144
