Ga door naar hoofdinhoud
How to Calibrate the Fingerprint Sensor in your Google Pixel Phone
  1. How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Connect your phone: stap 1, afbeelding 1 van 3 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Connect your phone: stap 1, afbeelding 2 van 3 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Connect your phone: stap 1, afbeelding 3 van 3
    • Follow these instructions to enable developer options and USB debugging mode.
    • If you're using a Windows operating system, download the Google USB driver and follow these instructions to install it.
    • Navigate to this page to prepare the calibration software.
    • If your phone isn't turned off, do so now.
    • Hold down the power and volume down buttons on your phone for three seconds to enter Fastboot mode.
    • Your phone will show a red warning triangle with the caption "Fastboot mode."
    • Plug your phone into your computer.
  2. How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Perform the calibration: stap 2, afbeelding 1 van 3 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Perform the calibration: stap 2, afbeelding 2 van 3 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Perform the calibration: stap 2, afbeelding 3 van 3
    • Select the "Connect Device" button.
    • Choose your device from the pop-up menu.
    • Depending on your browser, your pop-up menu will look different.
    • If your device isn't showing up, select the "Troubleshooting tips" link near the bottom of the page to diagnose your issue.
    • Once your device connects, select the "Install software" button.
  3. How to Calibrate the Fingerprint Sensor in your Google Pixel Phone: stap 3, afbeelding 1 van 3 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone: stap 3, afbeelding 2 van 3 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone: stap 3, afbeelding 3 van 3
    • Wait for the calibration software to download and install.
    • The program will run automatically and restart your phone.
    • After you receive the "Install successful" prompt, unplug your phone and manually restart it again to complete the calibration.
    • If you don't manually restart your phone, your fingerprint sensor will not work properly.
Conclusie
Your fingerprint sensor is calibrated and ready for use.
If the calibration fails for any reason, repeat the calibration procedure.
214 andere personen hebben deze handleiding voltooid.
Alex Diaz-Kokaisl
162.690 Reputatie
769 handleidingen geschreven
iFixit Lid van iFixit
Staff
119 Leden
19.475 handleidingen geschreven
98 opmerkingen
When I try and use the calibration tool on my Pixel 6 I get an error message whilst downloading the software that says "Couldn't find the unique calibration software for this device". Any suggestions as to what is causing this?
Isheanesu Gambe - Antwoord
Same problem. Pixel 7 android 14 latest update
Gleb -
Same problem. Pixel 6 android 14 latest update
Pavel DolĂ­nek -
Same problem, pixel 7 android 14 January update
Sunggat Yerzhan -
same problem. Please help
Stalyn Moreno Briones -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 450
Afgelopen 7 dagen: 2,897
Afgelopen 30 dagen: 10,913
Altijd: 190,557
