Inleiding
如果你忘记了屏幕锁定密码,如果你要删除个人数据,如果你遇到应用程序问题,你可以可以执行硬/工厂重置。
警告!!!
重置手机会清除手机上存储的所有内容,包括应用和游戏(以及应用数据和游戏进度)、短信、通话记录、音乐和照片等。
重置 Windows Phone 会将其恢复到第一次打开时的状态。 你的所有个人内容都将被删除,手机将恢复为出厂设置。
Video overzicht
关闭手机。
长按音量减键和电源键。
当你感觉到震动,松开电源键。
你会看到屏幕上显示一个感叹号(!)。
按照以下顺序按键:•音量加>音量减>电源键>音量减•
手机会重启。
你成功了吗?
本指南仅向您展示如何抹掉您手机的所有内容。
62 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
24 opmerkingen
i have a challenge with my Lumia 520 i cant see the apps the screen is fine its difficult to format and everything in the phone is ok just that i cant use the phone its been given me issues and i have taken it for repairs they confirmed it needs to be flashed but i dont know what to flash it with as all the technicians i took it too couldn't flash the phone
Nokia Lumia 520 IMEI 358106054625804
Will this's reboot setting helps my Nokia 520 if the touch screen is lagging and i can only use my screen for certain things?
Hi my Nokia Lumia 520 is behaving weird lately,hanging most of the time ,touch not functioning well,.Recently it request me to do booting , what am i supposed to do?
Kizito. 28/5/2018
What if my lumia 520 gets stuck on turning gears (reset mode)?
Gaand mein daal lena fir
hi Just to clear your doubt…Your nokia will never get stuck on the gears thing….maybe take a couple of hours…
I have a password in my phone but the error is “try again in 164325 minutes“ so the only way is the hard reset, but my volume up were broken. What am i suppose to do? Is there any other way to fix this? Or I’ll just wait for that 123456 minutes to be over!?
I'm having the same problem as yours. Have found ways to over come it. Please share. Thanks
Successfully working
my phone was switched off now when I switch it on its in airplane mode and it doesn't allow me to switch to 3G.
Comes ! exclamation sign but can't open?
It doesn't seem to be working for me but the phone is nearly dead and is on charge. Could that possibly be why?
after flashing my phone and follow the steps,when is time to bring out window symbol it off
cool jais réussir a réinitialiser mon phone
My lumia phone doesn’t recognize my sim card any more .Guidance please
My Lumia 520 decided to stay offline mode and I can't access the link to boot it
Yeah it was very helpful. Thank you ?
funciono 2022 febrero 23 gracias
Yo le hice reset a mi Nokia Lumia 520, pero ya no encuentra las aplicaciones en la tienda de Microsoft, solo sirve para hacer llamadas. ;-)
my nokia lumia is telling me to try again in15588 minutes please help
Yes, yes,and yes
kelvin arendse - Antwoord
Didn’t work for me, I have the explanation mark, but as soon as I press the power button after vol up and dwn, it goes away and starts as usual.
Simon Cusonnet - Antwoord
then how did you do it?
Arpanjot singh -
I can see the exclamation symbol, but it shows only the exclamation symbol, no more
Richyreaz - Antwoord
it has worked sucessfully
adams roland - Antwoord
Worked well eventually. Note to self: read instructions CAREFULLY, but it worked after I read them properly!
sue.edwards48 - Antwoord
Yes it worked great. I did remove the sim and sd cards beforehand so as not to accidentally erase my saved data . Reinstalled them after startup and my phone is now back to functioning as I want it. Thanks for the hand.
albert pruim - Antwoord
Am going through the process well but once it reboots the blue screen with sad face re-appears
robert gitende - Antwoord
mine is asking for the protection recovery key
coffi capello - Antwoord
thanks its so helpful
reason nhambura - Antwoord
No,flight mode always on after hard resetting
shavhani wa netshifhefhe - Antwoord
Thanks very much.am sorted.Viva!
Kipkemoi Kibiwott - Antwoord
Super!!! Muchas gracias fue de mucha ayuda
princesita696 - Antwoord
Yes. Good. It worked very well. Thank you. Absolute result. Not even expected the process would be like this
shiyaz khan - Antwoord
Very Good Solution. Thank You.
Lance Hildyard - Antwoord
i did all the proccess but still its reserting its been a day now.please help
mosime92 - Antwoord
You guys are awesome. M making money out of this. Thank you so much for the hand.
Brian Muuma - Antwoord
excellent piece of advice worked like a dream
kevin.pipefitter - Antwoord
When mine vibrates and I hold down the volume down button it just restarts over and over again help plz
Abs an a Am - Antwoord
mine never worked it keeps restarting
Caroline Darko - Antwoord
my never worked and please is there anyway out that you can help me
jedidiah - Antwoord
flight mode remains on
Gershom Bario - Antwoord
Thanks. Worked perfectly.
Tony Williams - Antwoord
Thanks....works perfectly
Dannie Chakholoma - Antwoord
