Inleiding
注意:如果你要在2009年及之后的苹果电脑上安装最新的macOS,请参阅MacOS 网络恢复指南。
如果你最近升级或更换了 MacBook, iMac 的硬盘,那么你需要重新安装 macOS. 这份指南将帮助你把 macOS High Sierra 安装到一个空的硬盘中。
“在开始之前,你得创建一个 macOS 启动U盘。”这需要你有一台正在运行 High Sierra 的 Mac,以便从 App Store 下载 7.7 GB 的安装文件。所以,你需要一个至少 5.4 GB 的空 U 盘。
在开始本篇指南之前,请根据这篇指南创建可启动的 macOS High Sierra U盘。
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
将电脑关机,并将所有移动硬盘和U盘从电脑上拔下。
在开机时按住[option]或 [alt] (⌥) 键,直到屏幕上出现启动选项的界面
用鼠标或是键盘上的方向键选择“安装 macOS High Sierra”。按[enter]或直接点击“安装macOS High Sierra”的选项
现在应该就可以开始全新安装 High Sierra 啦!享受这一过程吧。
590 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
62 Opmerkingen
I replace Toshiba MK1231Gal dard disk based on instruction on yutube http://www.youtube.com/watch?feature=pla...!
the problem is that when I try to install osx, I cant format the disk
I got notice input, output error, when try to make a partition or try anything with disk utility
I own MacBook air 1237
yes, me too...did you get it fix? please share how.
jay zee -
Use disk utilities from the Mac OS installer to format the new drive in a Mac format. Then install the Mac OS. New drive won’t show up in the installer until it’s Mac format.
A small pointer for any who have the same issue. I put in an entirely new 2TB WD sata drive and then preformed a fresh install of snow leopard onto it. When I got to the section to choose which drive to install to there was no drive image.
I clicked at the top on disk utility, then picked the drive, clicked erase and erased the drive. THis actually formats it into a mac format. after this I closed disk utility and voila the drive was now visible and installation could commence.
Good luck
