Video overzicht
- 没有定制化的螺丝钉。
- 一加5的显示屏是由分开和可从复使用的塑料夹子固定的。
- 大多数部件例如相机,type-c口,耳机插孔等用排线链接是模块化的,易于分离。
- 电池有一个拉环易于拆解,但是要移除主板才可以。
- 显示层和玻璃保护层被集成在了一起,home按键被集成在了显示模块中,这使得修复变得昂贵且复杂。
Laatste gedachten
Repareerbaarheidsscore
7
Repareerbaarheid 7 op 10
(10 is gemakkelijkst te repareren)
Met dank aan deze vertalers:
en zh
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
16 opmerkingen
Wow!! it is good, thank you.
Kaye - Antwoord
Wonderful video as usual. If one were to take theirs apart would it be as 'tight' once it was back together?
I think the buttons edges are a little sharp and I'm tempted to take it apart to put a little bevel on them.
I'd like it if the screen didn't end up being loose or have gaps around the back cover.
David - Antwoord
Is there an audio DAC founded? Can you tell us wich is it?
David Sepúlveda - Antwoord
The Snapdragon 835 has a built in DAC+amp with up to 4W output. https://www.qualcomm.com/products/snapdr...
George A. -
for those who dont have yootube and chance of a standard layout detaillng this teardown...?
P Stephenson - Antwoord
