Ga door naar hoofdinhoud
Philips Sonicare DiamondClean HX9340 Battery Replacement
Wat je nodig hebt
  1. Philips Sonicare DiamondClean HX9340 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Here is the Philips Sonicare handle HX9340 that no longer holds a charge
    • This is the bottom endcap that requires removal.
    • A few layers of cardboard gets wrapped around the handle to protect it from any marring or other damage.
    • BEFORE trying with tools, it is possible to get the cap off as well as the inner part of the toothbrush without any tools. This will not damage the toothbrush; actually it will possibly save the toothbrush from being marred.
    • Simply push the metal head at the top of the tootbrush downwards into a hard surface with some force and the bottom cap and the inner part will pop out by itself.
    • This works on both old and new Sonicare models.
    • If this worked for you, simply skip Steps 3–6.
  2. Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 3, afbeelding 1 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 3, afbeelding 2 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 3, afbeelding 3 van 3
    • Using a pair of pliers to apply some pressure round the handle. The best place to start is the wider part of the rectangular base and about 1/2" to 3/4" from the bottom
    • Continue to apply pressures around the whole base of the the handle moving to each side of the rectangular base.
    • It may take a few complete rotations to finally open up the gap between base and handle.
  3. Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 4, afbeelding 1 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 4, afbeelding 2 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 4, afbeelding 3 van 3
    • Once the gap opens up, utilize a small flathead screwdriver to insert it into the gap to widen it.
    • Endcap coming out of the handle. Once the gasket will become completely visible
    • the endcap can be removed.
  4. Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 5, afbeelding 1 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 5, afbeelding 2 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 5, afbeelding 3 van 3
    • Here is the endcap showing the tabs that hold it securely in place once inserted
    • There will be two plastic tabs that hold the inner workings to the outside handle. These are hard to reach and not easy to see.
    • Using a long small flathead screwdriver (or similar tool) to find those tabs is the difficult part on this job.
  5. Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 6, afbeelding 1 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 6, afbeelding 2 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 6, afbeelding 3 van 3
    • Once the tabs have been properly located, insert one tool on each side to loosen compress the base and apply downward pressure on the outer handle. For this the top end of the handle needs to rest against a solid base. It does require a considerable amount of downward force to accomplish this.
    • With the tabs loosened and the handle opushed downward, the inner workings of the toothbrush will loosen and pop out of the handle.
    • Remove the mechanics out of the handle.
  6. Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 7, afbeelding 1 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 7, afbeelding 2 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 7, afbeelding 3 van 3
    • Remove the rubber protectors from the PCB side
    • as well as the battery.
    • Here is the battery to be replaced. Sanyo part number 4235 010 13068
  7. Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 8, afbeelding 1 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 8, afbeelding 2 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 8, afbeelding 3 van 3
    • There are three places that will have to be desoldered.
    • Positive battery contact
    • Negative battery contact
    • and a jumper
    • For the jumper the only thing required is to remove the solder between the pads.
    • Apply some flux to the jumper. The pliers will help to stabilize the PCB during soldering. any other means to hold it steady can be used.
  8. Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 9, afbeelding 1 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 9, afbeelding 2 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 9, afbeelding 3 van 3
    • Using a soldering iron, remove the solder bridge between the jumper pads.
    • Using flux and desoldering braid remove the solder from the negative tab of the battery.
    • Solder bridge from jumper cleaned
    • Negative battery tab unsoldered from PCB
  9. Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 10, afbeelding 1 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 10, afbeelding 2 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 10, afbeelding 3 van 3
    • Apply flux to the positive contact of the battery on the PCB (Incidental finding is a SMD fuse F1 on this PCB)
    • Using desoldering braid unsolder the positive contact from the PCB.
    • Apply some gentle pressure with a small tool to remove the battery.
    • The battery should remove easily. If it does not, double check the battery contacts on the PCB to ensure they are not still connected somewhere. Another going over with the soldering iron may be required to complete that task.
  10. Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 11, afbeelding 1 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 11, afbeelding 2 van 3 Philips Sonicare DiamondClean HX9340 Battery Replacement: stap 11, afbeelding 3 van 3
    • Battery removed from the PCB and the solder pads on the PCB are now clearly visible
    • In an attempt to determine the type off battery the red plastic covering was removed. The battery is a 3.7V lithium-ion battery that measures approximately (rounded) 14mmX49mm. Roughly the size of a AA battery.
    • The groove on the battery is always on the positive end of the battery.
Conclusie
49 andere personen hebben deze handleiding voltooid.
oldturkey03
782.145 Reputatie
119 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
33 Leden
537 handleidingen geschreven
31 opmerkingen
This has helped me a lot and i used it as a base for my fixit tutorial. Thank you!
moritz - Antwoord
Hallo moritz, bitte tausche in deiner Anleitung die Sprache in Englisch da jetzt die Deutsche Anleitung in Englisch geschrieben ist.
Claes -
Nach dem wechsel der Batterie leuchten alle Lampen, aber die Bürste gibt keine Vibrationen ab. Wo ist der fehler? Hatte jemand dieses Problem?
After replacement of the akku all lamps are flashing but there is no function of the vibration-module. anyone knows this problem?
matze - Antwoord
Das wird wahrscheinlich daran liegen, dass zwischen der Antriebseinheit und der BürstenWelle kein Platz ist. Sprich der Magnet liegt auf der Antriebseinheit an. Um das Problem zu lösen musst du zwei feststellschrauben lösen, den Spalt herstellen und dann die feststellschrauben wieder anziehen. Dann sollte die BürstenAufnahme wieder schwingen.
Kilian Müller -
Thanks for information. This guide leads to success. *Thumbs up* My Sonicare is back at work now. :-)
Stephan Müller - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 32
Afgelopen 7 dagen: 291
Afgelopen 30 dagen: 1,226
Altijd: 125,334
