Battery
1 Antwoord 0 Score |
Powers up, but shuts down after 5 seconds |
2 Antwoorden 0 Score |
Why Won’t it power up |
No screen with ram in second (upper) slot |
Can't get windows to boot up |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Troubleshooting
For help on any trouble you may be experiencing, here is the Toshiba Satellite troubleshooting page.
Toshiba Satellite P855-S5312 Troubleshooting
Background
This device has a silver textured plastic cover with the Toshiba logo centered. Other models that have similar characteristics to the Satellite are Tecra, Portege, and DynaEdge. It has a 15.6 inch screen display and weighs 5.4 lbs. Two USB ports are located on the left side, two USB 3.0 ports on the right side, one SD memory card slot on the front right side of the device, and on the left side a DVD reader. It is equipped with a functioning Windows 8 operating system and Intel Core i5 (3rd Gen) 3210M / 2.5 GHz. It is equipped with 6 GB of ram with a memory speed of 1600 MHz .
Identification
The Toshiba Satellite has a model number of P855-S5312 and part number of 9C035938K which is printed on a white sticker found on the underside of device.
