Battery
1 Antwoord 0 Score |
Corrupted bios, need way to access and reflash |
How do I undo an update |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background
Toshiba Satellite M305D-S4829 is a 14.1” widescreen laptop equipped with AMD Turion™ X2 Dual-Core Mobile Processor, Genuine Windows Vista® Home Premium, 4GB PC6400 DDR2 800MHz SDRAM, and more. It has a pre-installed webcam for easy video conference and a 5-in-1 Bridge Media Adapter which can fit most of the memory cards in the market. Despite the variety of features equipped in this laptop, it only weights 5.27lb which is lighter than most of its competitors at the same level.
Identification
To identify if your laptop is a Toshiba Satellite M305D-S4829, simply check the label located on the bottom of your laptop and compare with the one in the picture.
