Battery
2 Antwoorden 1 Score |
Where is the hard drive |
Documenten
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Troubleshooting
If you are having difficulties with the Toshiba L15W-B1303, try referring to the Toshiba Satellite L15W-B1303 Troubleshooting Page
Background and Identification
The Toshiba L15W-B1303 is a small portable laptop with a 11.6-inch screen that was released in February of 2015. Its major features include a touchscreen, a 360-degree tilt, and uses windows 8.1 for it’s operating system. Unfortunately, this laptop has been discontinued and can only be bought refurbished.
This laptop is versatile, with the ability to work as a tablet or a laptop. It is an inexpensive solution for on the go work because of its tablet capabilities and how lightweight it is. It also includes solid state storage for better load times of applications. The most common problems reported with the Toshiba L15W-B1303 are issues with the storage capacity and short battery life.
The targeted demographic for this laptop is those who need a cheap and reliable option for a portable laptop. The model that came before the L15W-B1303 is the L15W-B1302. The L15W-B1302 was a very similar device however it had a much larger storage capacity of 500 GB, but the hard drive system it used was slower. The model that came after the L15W-B1303 is the L15W-B1320. The L15W-B1320 has faster processors, a bigger cache memory and more solid-state storage at 500 GB.
To make sure you have the correct laptop, make sure your laptop is in a fusion finish in gold satin. Also, look at the bottom of the laptop for the model number and it should tell you which model you have.
Specification
- Dimensions 11.4 x 7.8 x 0.9
- Display 16:9 LED Touchscreen
- Weight 2.87 lbs
- CPU Intel Celeron N2840 / 2.16 GHz
- RAM 2GB
- Graphics Intel HD Graphics
- Webcam Integrated Webcam
- Interfaces USB 3.0, USB 2.0 HDMI, SD Card Reader
- Hard drive capacity 32 GB SSD
- Battery life Up to 5.17 hours
