6 Diagrammen
1 Antwoord 0 Score |
part number for carburetor |
Modellen
20340
Background and Identification
The Toro 22in Recycler Lawn Mower with SmartStow® (model 20340) is a self-propelled gas lawn mower with a bagger. It is a rear-wheel-drive mower. The mower features a steel deck for greater durability, and its Personal Pace self-propel system makes pushing the mower easier. The 20340 model includes a 163 cubic centimeter Briggs and Stratton engine that produces 7.25 foot-pounds of torque. This mower is advertised to cut up to 1/4-1/2 of an acre of grass on a full tank of gas.
The Ego Walk-Behind Mower model 20340 can be folded and locked in place to save storage space; in its folded position, the mower provides easier access to clean under the deck and service the cutting blade. The blade has a cutting width of 22 inches or 56 centimeters. Users can adjust the height of the cut to between 1 inch and 4 inches with nine different height choices. Users can also adjust to two different handle heights without the use of tools. This mower uses patented ‘Recycler’ cutting technology to return nutrient-rich clippings back to the soil. Users can also switch between bagging and mulching with a quick-connect bagging system.
The Ego Walk-Behind Mower model 20340 lawnmower can be identified by the name ‘Recycler 22’ in white font on the front of the mower’s deck. The term ‘Personal Pace’ is printed in capital letters on a plaque near the push handles. The name ‘Toro’ is printed in various locations on the mower, including on its debris collection bag and on the front of the mower’s deck.
Technical Specifications
Dimensions:
- Assembled Depth (in.): 58.9 in
- Assembled Height (in.): 40 in
- Assembled Width (in.): 23.7 in
- Blade Length (in.): 22
- Cutting Width: 22 inches
- Front Wheel Size (in.): 8
- Mower Deck Width: 22 in
- Rear Wheel Size (in.): 11
Details:
- Assembly Required: Yes
- CA (CARB) Compliant: CARB Compliant
- Cutting Height Options: 9-position
- Cutting Options: Bag, Mulch, Side-Discharge
- Deck Material: 14 Gauge Steel
- Deck Type: Stamped
- Drive Type: Rear-wheel Drive
- Engine Displacement (cc): 163
- Engine Make: Briggs and Stratton
- Engine Torque (ft.-lb.): 7.25
- Features: Bagger, Deck cleanout, Foldable handle, Mulching Lawn Mower, No Oil Change Required, Tool-free adjustments
- Fuel Tank Capacity (gallons): .25
- Included: Engine oil
- Lawn Mower Type: Self-Propelled Lawn Mower
- Maximum Cutting Height (in.): 4
- Minimum Cutting Height (in.): 1
- Mower Size Type: Standard
- Number of Blades: 1
- Number of Handlebar Positions: 2
- Oil Capacity (oz.): 20
- Power Type: Gas
- Product Weight (lb.): 80
- Rear Wheel Height: High Wheel
- Recommended Oil Type: SAE 30
- Recommended Terrain: Sloped, Uneven
- Size of Yard: 1/4 - 1/2 Acre
- Start Type: Pull Cord
- Walk-Behind Mower Type: Self Propelled
