1 Antwoord 1 Score |
Is there a fix for fan speeed on this model? |
1 Antwoord 0 Score |
Laptop won't turn on after battery replacement |
150W charger used on laptop that came with 165w |
Can anyone identify the type of 30 pin connector of my display panel? |
Background and Identification
The Razer Blade 14” (Early 2016) was an update to Razer’s line of thin gaming laptops. The Early 2016 model was the first in the line to feature Razer’s chroma keyboard which lights up with various RGB patterns. With this revision, Razer also introduced the Intel Core i7 6700HQ processor to power the gaming machine. The graphics card —the Nvidia GeForce GTX 970M—is the same as the 2015 model.
This laptop uses 16 GB of memory which cannot be upgraded because it is soldered to the motherboard. The 256 GB or 512 GB SSD included in the laptop, however, can be replaced with any standard M.2 SSD. The battery, which is the part that usually dies first on a laptop, can also be replaced once you open the back of the device using a Torx T5 screwdriver. The procedure should be similar for any Blade 14” model from 2013 to 2016.
You can identify your Razer Blade by looking on the bottom for the model number. Use the Razer Support website to find the matching laptop. The model number for the early 2016 Razer Blade is RZ09-01652.
Technical Specifications
Processor
- Intel Core i7 6700HQ
- 4 cores, 8 threads
- 2.6 GHz with boosts up to 3.5 GHz
Memory
- 16 GB DDR4 soldered
Graphics
- Nvidia GeForce GTX 970M with 6 GB VRAM
Display
- 3200x1800 pixels
- Touchscreen
- 14 inches on the diagonal
Connections
- Two USB-A 3.0 ports
- USB-C 3.1 port
- HDMI port
- 3.5 mm headphone and microphone combo jack
Wireless
- 802.11a/b/g/n/ac Wi-Fi
- Bluetooth 4.1
Keyboard
- Chroma backlight
Additional Information
Razer Blade (Early 2016) specifications on LaptopMedia
List of Razer laptops on Wikipedia
Product page (256 GB) on Amazon
Product page (512 GB) on Amazon
