Battery
3 Antwoorden 8 Score |
My Powerbeats 3 won't turn on |
2 Antwoorden 0 Score |
Microphone stopped working and I can't be heard on calls |
1 Antwoord 1 Score |
volume control button cover came off |
Best Manufactur Adhesive to use? |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background and Identification
PowerBeats3 wireless earphones were released in September 2016 from Beats Electronics LLC (also known as Beats by Dre), which is now owned by Apple. They were the successor to the PowerBeats2 which were released in July 2014. And in 2020 the PowerBeats High-Performance Wireless Earphones were released.
The PowerBeats3 have an over-the-ear design to prevent them from falling out and have a cord to rest around your neck. They also have the familiar “b” logo on the side of each earbud for Beats to differentiate them from other brands. They’re available in black, white, siren red, shock yellow and flash blue. It has been noted that their design hasn’t changed too much from previous iterations.
Some of their features are noise cancellation, water resistance, and a variety of bud tips to fit your ears. The ear hooks are slightly adjustable for a better fit. They also have Apple’s W1 chip to pair with Apple products for easier syncing.
Specifications
- Impedance: 50.
- Driver Size: 10mm.
- Frequency Response: 20 HZ.
- Sensitivity: 96 dB.
- Cable length: 130 CM.
- Cable Connections: MMCX.
- Weight (including cable): 29g.
