1 Diagram
Populaire forumvragen
Stel een vraagEr zijn geen vragen. Wees de eerste om een vraag te stellen!
Documenten
Modellen
9524NB
Background
The Makita 9524NB is a 4-1/2 inch angle grinder suitable for grinding, cutting, and sanding tasks. This tool has a 5 AMP motor and a switch located on the motor housing. It also offers a small circumference barrel grip for handling. The labyrinth construction seals the motor and bearings from contamination, while the shaft lock allows for wheel changes. The side handle can be installed on either side of the tool.
Technical Specifications
- Motor: 5 AMP
- Switch Location: Top of motor housing
- Grip Type: Small circumference barrel grip
- Construction: Labyrinth construction
- Shaft Lock: Yes
- Side Handle: Can be installed on either side
- Protective Features: Zig-zag varnish seals motor from contaminants
Makita 9524NB And 9525NB Angle Grinder Manual
