1 Diagram
Populaire forumvragen
Stel een vraagEr zijn geen vragen. Wees de eerste om een vraag te stellen!
Modellen
GA7011CQ
Background and Identification
The Makita Angle Grinder model GA7011CQ is a 7-inch corded angle grinder with a side handle and a grinding wheel guard. Its 15-Amp motor delivers 6,000 revolutions per minute. The grinder is designed to protect the motor from dust and debris. It also features a rotatable gear housing that can be positioned every 90 degrees. The grinder’s trigger switch can be locked for extended operation and to make wheel changes with the shaft lock. The grinder can be used by welders, fabricators, and masons.
The Makita Angle Grinder model GA7011CQ is sold with a 7-inch grinding wheel (model 741413-3), a side handle, a tool-less wheel guard (122767-1), an inner flange, a lock nut wrench, and a lock nut. The grinder includes an AC/DC switch for use with alternative power sources. Users can position the side handle in three different positions. The GA7011CQ model includes a 5/8-11 UNC arbor and an 8.2-foot cord. The grinder includes externally accessible brushes for easier serviceability and a large rubber tool rest. The wheel guard can be adjusted without tools for easy clamping.
The Makita Angle Grinder model GA7011CQ can be identified by the name “Makita” in cursive font on the side of the tool. It includes a mainly teal-colored body with black accents.
Technical Specifications
Dimensions:
- Product Depth (in.): 18.625 in
- Product Height (in.): 5.5 in
- Product Width (in.): 7.875 in
- Wheel Diameter (in.): 7 in
Details:
- Amperage (amps): 15
- Arbor Size: 5/8 -11 UNC
- Color Family: Teal
- Cord Length (ft.): 8.2
- Corded Tool Type: Angle Grinder
- Cordless/ Corded: Corded
- Electronic Speed Control: No
- Maximum Speed (rpm): 6000
- Power Tool Features: Grinding Wheel Included, Lock-On Switch, No Tool Wheel Change, Second Handle Included
- Product Weight (lb.): 12.2
- Tools Product Type: Power Tool
- Variable Speed: No
