4 Diagrammen
Populaire forumvragen
Stel een vraagEr zijn geen vragen. Wees de eerste om een vraag te stellen!
Modellen
11938
Background
The Lincoln Electric Welder 11938 is a MIG wire feed welder, typically used in automotive and light fabrication. It employs Power MIG technology with a two-knob interface, facilitating quick setup and enhanced arc performance.
The welder has a rated output of 140 amps at 19 volts, using a mixed gas of argon/CO2 as shielding gas. It is capable of welding materials ranging in thickness from 24 gauge to 1/4 inch using solid or flux core wire. The wire drive system can handle wire sizes from .023 to .035 inches. The welder operates on 120/240 volt single phase power, requiring a 30 amp input circuit at 120 volts or a 20 amp input circuit at 240 volts. The welder's design includes thermal overload protection, a solid-state rectifier power system, and a dual-geared four-roll wire drive. Measuring 17 x 12 x 16 inches and weighing 54 pounds, the welder features a metal enclosure and a handle for portability. It comes with a 10-foot MIG gun, a 10-foot work cable with a clamp, and an integrated gas solenoid.
Technical Specifications
- Product Type: Welder
- Use: Automotive and light fabrication
- Technology: MIG wire feed with Power MIG technology
- Rated Output: 140 amps at 19 volts (mixed gas argon/CO2 shielding)
- Material Welding Capability: 24 gauge up to 1⁄4 inch thick using solid or flux core wire
- Wire Drive System: Can feed wire from .023 to .035 inches
- Power Requirements: 120/240 volt single phase power; 30 amp input circuit at 120 volts or 20 amp at 240 volts
- Safety Features: Thermal overload protection
- Power System: Solid-state rectifier with dual-geared four roll wire drive
- Dimensions: 17 x 12 x 16 inches
- Weight: 54 pounds
- Included Components: 10 foot MIG gun, 10 foot work cable with clamp, integrated gas solenoid
- Physical Features: Metal enclosure, handle for portability
Warranty
The Lincoln Electric Welder 11938 comes with a warranty that lasts for a duration of three years. This warranty covers both the parts and labor associated with any repairs or replacements needed due to manufacturing defects or issues that arise under normal usage conditions. To claim benefits under this warranty, you need to approach the network of authorized service centers provided by Lincoln Electric. These service centers are responsible for addressing and fixing any issues that fall under the warranty terms.
