8 Diagrammen
Populaire forumvragen
Stel een vraagEr zijn geen vragen. Wees de eerste om een vraag te stellen!
Modellen
G 3200 OC
Background
The Karcher G 3200 OC is a gas-powered pressure washer that was introduced by Karcher, a German cleaning equipment and systems manufacturer, in 2015. It is part of Karcher's line of pressure washers intended for home use.
The G 3200 OC has a 196cc Karcher engine that delivers a maximum pressure of 3200 PSI (pounds per square inch) and a flow rate of 2.5 gallons per minute. Its size is 22 x 35 x 23 inches (L x W x H) and it weighs 66.1 pounds. It has a Karcher commercial-grade axial cam pump with a brass cylinder head, a detergent tank with a capacity of 1.25 gallons, a fuel tank that can hold 0.95 gallons, a 25 feet high pressure hose, and a 35 feet power cord. The noise level is 82 dB. It is designed to generate over 60 times more pressure than a standard garden hose, making it capable for cleaning stubborn dirt, grime, and stains on surfaces such as patios, vehicles, and siding. The unit has an integrated hose reel, detergent tank, and storage for spray guns, wands, and nozzles. The gas-powered engine allows for independence from external power sources. The design facilitates easy access to the pump and engine for maintenance and repairs.
Technical Specifications
- Model Number: G 3200 OC
- Product Type: Pressure Washer
- Engine: 196cc Karcher
- Maximum Pressure: 3200 PSI
- Flow Rate: 2.5 gallons per minute
- Dimensions: 22 x 35 x 23 inches (L x W x H)
- Weight: 66.1 pounds
- Pump: Axial cam pump with brass cylinder head
- Detergent Tank Capacity: 1.25 gallons
- Fuel Tank Capacity: 0.95 gallons
- High Pressure Hose Length: 25 feet
- Power Cord Length: 35 feet
- Noise Level: 82 dB
Warranty
The Karcher G 3200 OC pressure washer comes with a limited warranty that lasts for a period of 2 years. This warranty covers the complete unit. To claim the warranty, users will need to contact Karcher's customer service or follow the warranty claim procedures outlined in the product's user manual or on the company's official website. It's important to keep in mind that the warranty may not cover damage due to misuse or failure to follow the product's maintenance guidelines. Always refer to the warranty information provided with the product for specific details and limitations.
