1 Diagram
Populaire forumvragen
Stel een vraagEr zijn geen vragen. Wees de eerste om een vraag te stellen!
Modellen
CAP 2060 PPK
Background
The Bostitch Air Compressor CAP 2060 PPK is an electric air compressor that was introduced in February 2013. This compressor has a capacity of 6 gallons, stored in a steel air tank. It operates through an oil-free pump, which eliminates the need for regular maintenance. The pump can deliver 2.6 SCFM at 90 PSI, reaching a maximum pressure of 150 PSI. The device has an integrated control panel, and its noise level is 80 decibels, allowing for a quieter working environment. Weighing 33 lbs, the CAP 2060 PPK is designed to be portable.
In terms of technical specifications, the air compressor operates at a power source of 120V electric and uses 12 Amps. Its pump life is estimated at 450 hours. The dimensions of the compressor are 16.5 x 16.13 x 22.06 inches. Despite its compact size, the design of the air compressor is such that it supports the connection of two air tools simultaneously, utilizing universal quick connectors. It also comes with a 6ft power cord and features manual pressure regulator and gauges. The CAP 2060 PPK is suitable for both DIY users and professionals who require a portable air power source.
Technical Specifications
- Model Number: CAP 2060 PPK
- Product Type: Air Compressor
- Tank Capacity: 6 gallons
- Pump Type: Oil-free
- Air Delivery: 2.6 SCFM @ 90 PSI
- Max Pressure: 150 PSI
- Noise Level: 80 dB
- Power Source: 120V electric
- Current Draw: 12 Amps
- Pump Life: 450 hours
- Dimensions: 16.5 x 16.13 x 22.06 inches
- Weight: 33 lbs
- Portability: Portable design with integrated control panel
Warranty
The Bostitch Air Compressor CAP 2060 PPK comes with a two-year limited warranty. This warranty covers any defects in materials and workmanship that might arise during normal use. However, it is important to note that the warranty does not cover normal wear and tear or any damage that may result from improper use or maintenance. To claim the warranty, you should follow the guidelines provided by Bostitch, which typically include contacting the manufacturer directly and providing details and proof of the defect or issue.
